www.photomacrography.net :: View topic - My Setup
My Setup
Goto page 1, 2  Next
marc
PostPosted: Sun Mar 21, 2010 7:01 am    Post subject: My Setup Reply with quote
here are some pictures of the setup I used to make these pictures: http://www.photomacrography.net/forum/viewtopic.php?t=9239
Cheers,
Marc
1. Schott KL 1500 fiber optics light source
2. a 35kg block of Greek marble Shocked
3. 2x 10kg handle weights
4. Sorbothane bumbers to isolate the setup from vibrations
1. Novoflex Universal bellows BALPRO 1 with CANON EOS adapter
2. RMS->M42 and M42->EOS adapter to mount microscope objectives
3. Novoflex CASTEL-L focusing rack for coarse movement along the X-axis
4. Novoflex CASTEL-Q focusing rack for coarse movement along the Z-axis
5. DIY adapter steel plates
6. Newport M-433 translation stage with SM-25 actuator
7. a mirror of polished metal for convenient reading of the micrometer scale
8. an additional stand for mounting flash lights, diffusors and backgrounds
1. Thorlabs 1.5" post P200/M
2+3. Thorlabs mounting clamp C1501/M
4. Thorlabs dovetail optical rail RLA150/M
5. Thorlabs rail carrier RC1 for coarse movement along the Y-axis
6. Thorlabs mounting post base PB2/M
7. Thorlabs dovetail translation stage DT12XZ/M for fine movement along the X- and Y-axis
8. DIY adpater steel plate
9. Thorlabs rotation platform MSRP01/M for Y-rotation
10. Thorlabs dual-axis goniometer for X-Z-rotation
11. DIY steel plate with a mounted object slide
12. small magnet with a glued pin to hold the specimen
[/img]
http://flickr.com/photos/grosskopf
AndrewC
PostPosted: Sun Mar 21, 2010 11:45 am    Post subject: Reply with quote
Very elegant Smile
How did you attach to the marble slab ? Drill holes and insert plugs or epoxy to the surface ?
Andrew
PostPosted: Sun Mar 21, 2010 11:50 am    Post subject: Reply with quote
An elegant and sophisticated setup, to say the least!
Your results speak for themselves, but I'm curious to know how it feels to adjust an SM-25 actuator with a 2 µm increment.
Here is my thinking... The SM-25 is described as having a vernier reading of 1 µm, but the screw pitch is 0.5 mm. 2 µm is only 1/250 of a full turn, and the scale diameter appears to be only 1.5 cm or so. Contrast this with an Olympus CH microscope focus block, where 2 µm is 1/100 turn and the scale diameter is 5 cm. On the surface, it seems like the focus block should be "over 8 times easier to set!" (written as advertising hype for amusement).
But I have not had hands-on an SM-25, so I don't know what it feels like.
What are your thoughts?
marc
PostPosted: Sun Mar 21, 2010 1:07 pm    Post subject: Reply with quote
Andrew, I drilled holes using a drill stand and inserted metal dowles for the screws.
Rik, moving the stage in steps of 1µm is a really hard job. But 2µm will be possible if you have a steady hand. What you say about the microscope block sounds much more convenient. I already started thinking about a motorized stage which is capable of much smaller increments Smile
AndrewC
PostPosted: Sun Mar 21, 2010 1:20 pm    Post subject: Reply with quote
marc wrote:
.. I already started thinking about a motorized stage which is capable of much smaller increments Smile....
Do it - it makes life a lot more fun !
Andrew
DQE
PostPosted: Sun Mar 21, 2010 1:25 pm    Post subject: Reply with quote
Thanks for posting the photos of your rig.
It is aesthetically very appealing and these rig photographs were very well done.
The blue colored parts of the Novoflex components really blend in nicely with the rest of the rig's colors. To my eyes, it creates a nice, high-tech, high-precision look that I personally enjoy. It's always nice when the appearance of one's equipment is enjoyable.
I very much look forward to seeing more of your photos!
-Phil
"Diffraction never sleeps"
PostPosted: Sun Mar 21, 2010 10:04 pm    Post subject: Reply with quote
Marc, beautiful setup and documentation!
Am I missing something, or does it appear that you are impossibly shooting through the vertical post that holds the subject stage? Surely you're turning the subject stage around to the camera side of the vertical post, right?
Cheers, and thanks much for sharing.
--Chris
bklein
PostPosted: Sun Mar 21, 2010 10:45 pm    Post subject: Reply with quote
Ok now show us the rig used to take THESE photos. Very cool.
View user's profile Send private message AIM Address
PostPosted: Sun Mar 21, 2010 10:51 pm    Post subject: Reply with quote
Laughing Laughing
I confess, I had exactly the same thought! Java developer by day, industrial photographer by night?
marc
PostPosted: Mon Mar 22, 2010 7:33 am    Post subject: Reply with quote
Thanks for your comments.
Chris, I have to admit that this might not be clearly visible. When you look at the second photo you will find the post behind the camera. The camera is mounted in the middle of the marble block and the post is mounted at the edge. This is visible on the third photo where the specimen pin is roughly in the line of the optical axis of the camera.
Just a tripod an two diffused flashes Very Happy
If I can spend six hours to photograph a bug's eye, I can easily spend one little hour to shoot my rig. I just noticed that I did not very well. My living room table is visible at the lower right corner on the first image.
stevekale
PostPosted: Sun May 15, 2011 1:35 pm    Post subject: Reply with quote
Very impressive, and I assume expensive! One question: how do you get fine adjustment of the vertical axis?
PostPosted: Sun May 15, 2011 2:51 pm    Post subject: Reply with quote
In the third image, see component 7, the "Thorlabs dovetail translation stage DT12XZ/M". This component consists of two linear slides mounted at right angles. The lowest silver-colored handle controls the vertical axis (Y, in marc's notation), while the upper silver-colored handle (between the labels 7 and 8 ) controls the horizontal X-axis. The manufacturer describes this part as an XZ Dovetail Translation Stage and shows it in a different orientation with a different labeling of the axes.
g4lab
PostPosted: Sun May 15, 2011 3:57 pm    Post subject: Reply with quote
I never get tired of looking at list members' setups.
Beautiful rig, and beautifully photographed!
PostPosted: Sun May 15, 2011 4:14 pm    Post subject: Reply with quote
Yes, and this one is spectacular. Marc hasn't been around lately. I wonder what he's doing?
stevekale
PostPosted: Mon May 16, 2011 12:34 am    Post subject: Reply with quote
Paying off his tab at Thorlabs! Very Happy
(Somewhere here I saw a step by step of someone making either this or a very similar setup. I can't find the thread now. If someone could PM me the link I'd appreciate it.)
Goto page 1, 2  Next
Page 1 of 2
