Charles Krebs wrote:Paul... you need to be a little careful with white plastic bags. Some seem to "filter" out much of the blue light and can lead to quite ruddy results.
I'm enjoying this discussion, but will admit I am a little perplexed that there's been no mention of the many various polyester Lee and Rosco products that specifically made to diffuse light. Certainly tougher than paper towels and tissue, nice clean color, and not very expensive. If you have access to a store with a "pro" lighting department you can buy it by the "foot" from a 48 or 60 inch roll at a very reasonable price. (Or you can order sheets online at a place like this
http://www.filmtools.com/leedifsheetx.html).
There's a pdf here that compares the "diffusion" of the various Lee materials.
Similarly, B&H sells a pack of twelve Bogen FP211 Diffusion Filter sheets, with varying degrees of diffusion. The size is 12 x 12 inches (30 x 30 cm). I bought this set and was reasonably satisfied with their uniformity, quality and utility. They are made to good quality specs, based on the BH specs page, hopefully avoiding unwanted color casts, etc, in photographic uses. As best I could tell from a superficial examination, they use tiny matte beads in a coating to create the light diffusion. Such matte beads are commonly used in various gloss-reduction spray paints and coatings to create a dull or light-diffusing surface. A link to this inexpensive (23 US dollars) set of filter sheets is provided below:
http://www.bhphotovideo.com/c/product/2 ... Pack_.html
Interestingly (from distant memory), 3M embeds tiny spheres in a paint to create a retroreflective surface, as seen in reflective tapes and signs. These little spheres geometrically retroreflect incident light when immersed in a medium of a certain refractive index if my aging distant memory is mostly correct for a change.
Diffusing light through optical turbidity is a surprisingly important branch of optics and materials design. Titanium oxide powder (again from distant memory) is commonly used as an efficient white diffuse reflector. Barium sulfate is highly reflective and optically diffusive as a powder. Also, tiny methyl methacrylate spheres are often coated onto surfaces to create a light diffusing effect, but my aging memory is incomplete as to the common applications of this material.
An enjoyable discussion, with a nice mixture of DIY experimental efforts and commercial materials. I continue to have the impression that macro photographic illumination has not been fully investigated in a thorough, quantitative, systematic fashion yet. Part of this is because our needs and preferences are as complex and varied as our subjects!
