You can consider me to be about 150% agreed with you about the value of scale bars.
The number is larger than 100% because I'd go even farther than you've said, and note that scale bars are really valuable even for "familiar" subjects.
A few minutes ago I made the following picture, showing two beetles that I personally have picked up on the streets of U.S. cities.
Without the scale bar, would anyone care to commit themselves about how large these things are?
No, the picture is not faked. The larger beetle is a Long Horned Wood Borer (Coleoptera:Cerambycidae), total body length 75 mm from posterior to mandibles. The smaller one is a Carpet Beetle (Coleoptera:Dermestidae), total body length 2.5 mm.
OK, so the picture's real. But is it "really macro"?
What do you say, folks, and why?
For beginners to macrophotography.
- Mike B in OKlahoma
Waaaaay back in high school, I wasn't a photographer, but I was curious enough about it to read a book on closeup photography. The photos in the book had captions such as "fly shot at 1x" and similar. I was quite put out, since it was "obvious" to me that what the magnification was depended on how much you blew up the photo and printed it in the book! I did eventually figure it out, though.
The term macro is hopelessly muddled, and barring a decree issued by a world dictatorship founded by a totalitarian closeup photographer, I doubt we're going to clear it up, whatever definition we might come up with here.
For myself, I sling around "macro" quite a bit, but when I use it, I usually mean (and I assume the other person means, in the absence of agreement on a definition) "closeup photography of some sort". Of course, if I decide I want to be a jerk, I have the option to jump in when the other person uses macro loosely, and say "You realize that macro only refers to magnifications on the film or sensor greater than 1:1, right?"
I think everybody would agree that a scale on the photograph helps because the final magnification can vary according to the media it is reproduced on. Many of our computer monitors differ in size, so we will see 1:1 images from the camera reproduced at different sizes, and what about natural history films shown at the cinema in the past. A 1:1 image in camera is hardly being reproduced at 1:1 if it is shown on a 30 foot cinema screen, the same applies to a lesser extent for slide shows.
But from an equipment point of view it is handy to know if it will reproduce the subject natural size on the film or sensor. Therefore to fill your 4"x5" film frame with an image that fills our APS sized sensor you are going to need large format equipment that renders the subject many times life sized.
You will also probably not get any better quality using large format to photograph the small subject at 1:1 on the film because you would have to enlarge this small section just as much as is required for the APS sensor and that would show the grain, plus enlarge the circle of confusion to the same extent.
Your only advantage using large format therefore would be photographing larger objects at 1:1 not smaller ones, because for smaller ones either you need to enlarge the image similarly on reproduction to match that of the APS sensor, or invest in much more expensive equipment that will produce far greater magnifications than 1:1 to fill the 4"x5" film frame. And this may be even harder to find than for 35mm or APS.
There seems to be little to gain photographing objects as small as the APS sensor at 1:1 on 4"x5" film because the final enlargement of the subject has to be the same for either format to produce equal final magnification for the viewer. In the end, not knowing the final magnification the subject will be shown at, there are only two useful pieces of information. The most useful being a scale on the photograph and the other that the equipment used rendered the subject at 1:1, or life size, on the film or sensor. Final magnification can be worked out from both those facts, other designations are misleading.
The general rule in science is a term means what the original coiner of the term meant by it. Alas, I don't know who first invented the term Photomacrography and when it was first used, or even how they defined it. After all the term Photography itself is not really descriptive because it means "writing with light" whereas a better term would be "imaging with light". Language is just a means of communication, as long as it does that it has achieved it's purpose, whether it is correctly used or not!.
DaveW
DaveW
DaveW,
I'm still puzzled about the fixation on 1:1.
You write that "it is handy to know if it will reproduce the subject natural size on the film or sensor."
I don't think I've ever cared about that, except as a fluke of working with a subject that happens to be the same size as my equipment.
Now if you had said "it is handy to know if it will reproduce the subject full frame on the film or sensor", then I would be in complete agreement.
Full frame matters because it affects secondary aspects of image quality, such as film grain or sensor pixelation. 1:1 matters only because, um, actually I can't think of a good reason.
Maybe I'll just have to stay puzzled about this. Sometimes what people care about is just a matter of taste and can't really be explained.
You raise a good point about the coiner of a term getting to define what it means.
I don't know who first used the term "photomacrography".
But I do know some of the field's other history, and I think you might find it interesting.
You are correct that there's little to be gained in photographing small objects at 1:1 on 4x5 film.
In fact, a much stronger statement is also true: there is little to be gained in photographing small objects on 4x5 film at any magnification.
What's interesting is that this statement would have been considered completely wrong, verging on heresy, by early experts in photomacrography.
In 1960, an article titled "Magnification and Depth of Detail in Photomacrography" was published in the PSA Journal. Written by H. Lou Gibson, that article was a masterpiece of analysis and exposition. It quickly became a dominant reference in the field. Its conclusions and recommendations were adopted into other publications, and became the basis for equipment selection and setup for many years afterward. They're still used even today.
One important conclusion of the article was that bigger is better, in the specific sense that recording at high lens magnifications was shown to yield more DOF at same resolution, compared to recording at lower lens magnifications and then enlarging. The difference was not huge, but it was significant, and the recommendation was clear: to get the greatest DOF, use the greatest lens magnification. Quoting from the article: "Then the depth requirements would lead to the selection of an appropriate camera magnification."
This conclusion was supported (weakly) by some photographic experiments, but Gibson had worked out the math in gory detail, starting from a detailed and completely reasonable model of the imaging process. The conclusion -- that higher lens magnifications give more DOF -- was shown to be a fundamental property of optics.
Unfortunately, there was a mistake in the math. It was a small mistake -- use of lower-case "m" instead of upper-case "M" in one formula, as I recall -- but it was enough to completely change the character of the result.
With the formula corrected (in 1986!), the apparently fundamental advantages of larger lens magnification disappeared from the math, leaving only secondary issues such as film grain and enlarging lens blur.
Since then, further advances -- notably lossless enlarging from small digital sensors -- have removed even most of the secondary issues.
Another general rule in science is that understanding evolves.
We now understand that lens magnification by itself is of no significance. The important thing is to fill the sensor, and even that doesn't matter if the sensor has more resolution (more pixels) than you need in the final image.
References:
a) The history is reviewed at http://www.photomacrography1.net/forum/ ... 6&start=30 and its predecessor postings, which provide other links and references.
b) The quote from Gibson's article is page 41, left column. The accompanying table shows computed DOF as 1.9mm for lens magnification m=2, versus 2.6mm for m=5.
References:
Interesting topic.
Someone asked on flickr what my definition of macro was and I didn't realise that I came up with the "kodak" definition -
" I prefer an easier definition of- It should show detail on the PC screen that you cannot see with the naked eye."
I later added when the subject was within arms length to deter telephoto shots.
As far as magnification definitions are concerned I'm happy with the 1:1 sensor definition as it describes the lens not the camera. I also sometimes use the term Print magnification to cover what the user finally sees.
I have had very confusing discussions with people about this but think it is valid as described above where someone using a P&S camera in super macro mode can shoot at 0.3:1 (approx) and produce the same print magnification (at approx the same print size) as me shooting at 1:1 with my 1.6 crop camera.
brian V.
brian V.
www.flickr.com/photos/lordv
canon20D,350D,40D,5Dmk2, sigma 105mm EX, Tamron 90mm, canon MPE-65
Brian,
The question of what it means to be "macro" was explored in much more detail in another series of postings: http://www.photomacrography.net/forum/v ... .php?t=910 .
There was considerable debate about my proposal, which prompted me to delve more deeply into the history of the term.
It turns out that the fellow who coined the term "photomacrograph", way back in 1902, defined it as follows:
In fact, I don't see any reason to add some caveat like "closer than arm's length". The light does not care. Revealed detail is a function of magnification and aperture size (cone angle). It makes no difference to the light whether an image was captured at 6 inches or 6 feet, as long as the cone angle and final magnification are the same. The longer distance will require a much larger lens, of course. One might want to think of it as "long-distance photomacrography".
It's true that the original author's example used a single microscope objective to project a magnified image onto a photograph plate, in a single step. But that was just a particular method. Adding "1:1 or higher on the film" into the very definition was done by later authors, for reasons that may have been clear at the time but are no longer relevant.
All that you and I are doing is getting back to basics.
I think it's important that this definition says absolutely nothing about the lens system that produces the picture, only about the picture itself, which must be "slightly enlarged". I believe the point of enlargement was to show detail that could not be seen on the real subject by the naked eye, at closest viewing distance. So, in this brave new world of low-resolution monitors, I think it's completely consistent to re-interpret the original definition in terms of visible detail.Photo-macrography. Worcester defined Macroscopic or Macroscopical as "noting an object which, although comparatively minute, is visible to the naked eye or to the eye assisted by a pocket lens," -- usually an inch or more in focus and magnifying less than ten diameters. A delineation or picture of an object thus enlarged would be a macrograph, and if produced by the aid of photography, why should it not be termed a photo-macrograph? At all events I have chosen to coin that word and to define it as a slightly enlarged picture or delineation of a macroscopical object produced by means of a lens and sensitized photographic plate.
A missed Opportunity
What a pity that "zoom" is used for other purposes! It might have done the job, perhaps with a selection of prefixes to meet various applications.DaveW wrote:Yes, it should be Photomacrography according to Lester Lefkowitz and Kodak, but I have now given up trying to convert the masses!
According to them:-
Close-up Photography = photographing subjects at between 1:10 and 1:1 (usually called Macrophotography by the photo press!)
Photomacrography = photography using the camera and usually extension from 1:1 upwards. (still called Macrophotography by the photo press!)
Photomicrography = photography through the microscope.
Macrophotography = making very large photographs e.g. advertising hoardings or large display photographs.
Microphotography = making very small photographs e.g. microfilm or microdots so beloved by spy writers in James Bond type novels.
However I once explained this to a photo journal editor, obviously just a general photographer, and he claimed everybody in the industry knew it was Macrophotography not Photomacrography or they would all be calling it that.
As I say, I now simply use the language of the masses unless I am dealing with you lot that know the difference!
DaveW
