AO Spencer Junior, Vintage 1940 Stereomicroscope
I recieved this as a gift quite unexpectedly and needless to say I am very greatful indeed. This little microscope is only nine inches tall and boasts some of the best optics you could expect to lay your peepers on or through. All mechanisms are tight and perfectly machined and fitted, there is no play in any moving parts. The lenses are exceptionally clean, color corrected I am assuming since I noticed no color fringes in some of the things I viewed and the image presented is very sharp. The body of the scope is cast metal with a wrinkle black finish, except for the binocular housing which is smooth and polished. A beautiful little stereomicroscope.
The eyepieces are 12X with the objectives being 1X and 2X. A stainless steel lever and a spring loaded latch enables the turrent to be turned and locked in place. The binocular housing is fully adjustable for pupil distance.
- Mike B in OKlahoma
Congrats on your gift, Ken! From the "Junior" in the name, I'd have guessed this was intended for science-oriented kids (I had two mono microscopes between about 9 and 14 myself), but it looks like a professional piece of equipment from what I can see of the build.
MikeB replied:
Indeed it is built to professional standards Mike, they don't make scopes this well anymore and if they do, they are going to be quite expensive; I think it was intended for a classroom environment also. There are several attachment points on this little scope which tells me that there is a whole lot more to it than what I now have. I searched the internet hoping to find the complete set up for this scope but have found nothing on it. I guess it is too out dated, however, its optics are not.it looks like a professional piece of equipment from what I can see of the build.
Ken,
Go to this site: http://xmission.com/~psneeley/Personal/Microscope.htm
and download the AO Blue Book (yes, it's big, but it's good). Now take a look at pages 132 to 134.
Hope this helps,
Steve
Hope this helps,
Steve
Yes . . . somebody's spent way too much time
But, if you have problems getting the blue book to download, tell me how to send you those pages and I will -- no problem -- I can send them as jpeg if needed. They tell all about your scope and answer all the questions above, etc.
That is a fine scope, BTW. All the 'black' scopes by AO Spencer were just absolutely the best . . . so too were many of the later scopes. As you've discovered, you won't find better optics, IMHO.
