Mayfly Nymph - 2nd image added
One of the live specimens from my recent 'ditch dipping' exercise.
Full frame, single frame. Tried stacking multiple frames but this nymph moved its 'tails' between frames plus the gills on the sides of the body never stopped moving.
Note the 4 eyes, with the lower ones developing first as I can see the eye facets.
Anyone recognize the plant (alga?)
Reversed El-Nikkor 63/2.8 enlarging lens @f/8
NU09238
NU09238
NU.
student of entomology
Oliver Wendell Holmes, Sr
Thanks Betty, seems an accurate ID.
Laurie:
No, flash from the side. White sand on a white background. On left side the sand is not as thick as that on the right. The very light coloured sand is probably reflecting the light upwards giving the impression of a backlit subject.
Laurie:
NU.
Re: Mayfly Nymph
Spyrogira?NikonUser wrote:Anyone recognize the plant (alga?)
12oBin: Yes, a photo of a living nymph in a shallow dish of water; flash illumination diffused through half a hollow plastic baseball
SEE BOTTOM OF THIS PAGE
Larry: Definitely not Spirogyra. I'm convinced that Betty's ID is correct.
Spirogyra is a very distinctive filamentous alga with helical chloroplasts. This alga's chloroplasts appear to have no structure - except perhaps suusage-shaped
NU.
Wonderful shot - the lighting gives the shot a very flat impression- almost like a fossil.
Brian v.
Brian v.
www.flickr.com/photos/lordv
canon20D,350D,40D,5Dmk2, sigma 105mm EX, Tamron 90mm, canon MPE-65
Brian v wrote "the lighting gives the shot a very flat impression- almost like a fossil"
Showing a bias towards my entomological side rather than my (limited) artistic/photographic side.
Not too surprising that the image is flat, the 1/2 hollow plastic baseball diffuser around the nymph created very even lighting.
That said, I tried another shot (different nymph) with a single flash at a very low angle and no diffuser around the nymph. Image was again flat, an effect that is probably due to a subject in shallow water and on a white sand bottom.
NU09239
NU09239
NU.
No criticism intended- I rather like the effect
As is often the case it all depends on what you wanted to achieve in the first place
Brian v.
Brian v.
