www.photomacrography.net :: View topic - Beyond 10x, below 40x
NikonUser
PostPosted: Wed Nov 11, 2009 2:30 pm    Post subject: Beyond 10x, below 40x Reply with quote
Nikon's CF objectives are versatile lenses that can be used at other than their designed tube length (and thus, magnification).
Beyond 10x
The 10x Nikon CF N Plan Achromat microscope objective can be 'pushed' to at least 20.3x (on a 23.6mm sensor). This 0.7mm long Closterium (a Desmid) was taken at full bellows extension + lens mount; horizontal FOV=1.16mm; 24 frames @ 0.002mm ZS PMax stack.
NU09237
Below 40x
Compare the image from the 10x objective with the one taken with a Nikon CF M plan 40x SLWD at minimun bellows extension to give 24.4x magnification.
HERE
Both lenses perform well beyond their 'optimum' magnifications
NU.
student of entomology
Oliver Wendell Holmes, Sr
PostPosted: Wed Nov 11, 2009 3:02 pm    Post subject: Reply with quote
Fascinating, and a nice image right at the 'wouldn't it be better to do it with a microscope' transition point.
NikonUser
PostPosted: Wed Nov 11, 2009 3:12 pm    Post subject: Reply with quote
I guess I would have got a 'better' image with a microscope; but not having a microscope I have to compromise with a camera, bellows and microscope objective.
NU.
AndrewC
PostPosted: Wed Nov 11, 2009 3:46 pm    Post subject: Reply with quote
How about stitching the two images together - left half 10x, right half 40x - it would make it easier to compare the two ?
Andrew
NikonUser
PostPosted: Thu Nov 12, 2009 8:48 am    Post subject: Reply with quote
I thought about that. My point was to show that these 2 objectives can be used at magnifications way beyond their deginated magnifications. I didn't want to make a statement regarding whether the 40x at lower mag is better/worse than the 10x at a higher mag. That's one reason for not having both images in the same forum.
I thought both lenses did a splendid job; the most important factor was the lighting. Because I use flash it is not possible to get identical lighting between series of frames. So a direct side-by-side comparison of the 2 images would reflect differences in lighting rather than differences between the optics.
NU.
AndrewC
PostPosted: Thu Nov 12, 2009 8:58 am    Post subject: Reply with quote
Fair enough.
Andrew
PauloM
PostPosted: Fri Nov 13, 2009 6:30 pm    Post subject: Reply with quote
Splendid images.
I can't help wondering how a M Plan 20x (E|S)LWD would compare, though.
Perhaps someone with access to all three lenses could make a comparison shot.
If the difference is imperceptible, then I can stop my search for the very elusive
and expensive 20x ELWD.
Cheers,
Paulo
