Cruising the local Craig's List ads for microscope and microscope parts, I stumbled upon a great find - a Nikon Optiphot with 2 phase contrast objectives, and a 100X objective.
The microscope was sold as broken, but it looks like it's primary problems were that it was dirtier than sin and missing an illuminator.
I am unable to use the microscope as is, but I am able to use the objectives and condenser on my current microscope. even better, the Nikon Objectives are keyed the same as my current ones, and only require fine focus adjustments when switching.
My problem: I have 5 objectives I want to use, but only 4 mounts.
I want to use:
Plan 40X PH3 0.70 NA
Plan 10X PH1 0.30 NA
LP SemiPlan Achromatic 40X 0.65 NA
LP SemiPlan Achromatic 10X 0.25 NA
LP SemiPlan Achromatic 4X
I'm considering this lineup:
Plan 40X PH3
Plan 10X PH1
Has anyone has regretful experiences with using a phase contrast objective in brightfield applications?
5 objectives and 4 mounts.
Re: 5 objectives and 4 mounts.
specious_reasons wrote:Cruising the local Craig's List ads for microscope and microscope parts, I stumbled upon a great find - a Nikon Optiphot with 2 phase contrast objectives, and a 100X objective.
I want to use:
Plan 40X PH3
Plan 10X PH1
Hello,
Aside from the phase ring being in the image no. I'm not noticed any difference between brightfield and phase contrast use.
regards,
Hokan
SOM, (Son Of Multiphot), a DIY macro/micro rig.w/120, 65, 35, 19mm Macro-Nikkors, Nikon AZ100 1X and 4X objectives. Nikon Plan Fluor W objectives, 10X, 20X, 40X.
With Zeiss infinity objectives, LD, Epi, APO, Plan types.
