Hello Barry,Barry wrote:Interesting data.
Recently I tested a 12cm Macro-Nikkor, 63mm Luminar, 50mm and 63mm El-nikkors (N-series) and a Tominon 105mm.
Camera was Canon 450D (now replaced). Bellows draw available up to 600mm. Illumination was fibre optics through transparent paper.
Did not print the images - my opinion is based on viewing at 100% at computer screen.
I found that, at all magnifiations, the Macro-Nikkor and Luminar were superior to the EL-nikkors and Tominon. No doubt. As to be expected, from litterature.
Sharpness is at least slightly better, colour and contrast certainly better.
The apertures I found best were at both macro lenses ap=1.5 (1 is a little bit soft), the EL-nikkors 5.6. For up to 2x I now use the Macro-Nikkor, for 2x-4x the Luminar.
BUT, another view may be:
The EL-nikkors and Tominon were bought for €25,-- (US $35), which is a big contrast compared with the macro lenses.
And in which cases are the difference in quality (post-processing included) really noticeable?
Cheers,
Barry
Not disagreeing with your findings or conclusions. I would just be curious as to what specimen(s) you used across all lenses and what type of illumination you used. I've found the El-Nikkors to be less then their best when used with specimens requiring more than 0.1mm DOF. Again using 35mm sized sensor as standard. However within their 0.1mm or less DOF they come into their own sweet spot. Stacking would quickly revise my last statement.
regards,
Hokan
