Botanical Microtechnique: Staining Fresh Material
Probably the most beautiful results can be obtained by cutting and staining fresh material. In this post I will explain how to fix and stain cuts.
We will need some chemicals and some equipment:
Isopropyl pure
Ethanol 70%
Ethanol 50%
Ethanol 30%
Aqua dest.
Etzold Staining Solution (Astra Blue, Fuchsine, Chrysoidine)
Fixation Solution AFE (90% Ethanol, 5% Formalin, 5% Glacial Acid)
Euparal
Pipette: 4x
Watch Glas
The general procedure will be to leave the cuts in the watch glas and remove the chemicals with a pipette. Use 1 pipette for AFE, 1 for Ethanol, 1 for Aqua dest and stains, 1 for Isopropyl. It is very important that the Isopropyl is as dry as possible. Water in the Isopropyl will remove the Chrysoidine. It is a good idea to shake the watch glas a little bit after a new chemical is applied.
Fill the watch glas (or another small container with a similar form) with AFE. Now cut fresh material either by hand or a small microtome. Each section that is cut will be put into the watch glas. After the last cut is safely in the watch glas, simply follow this procedure:
15 min AFE, then remove with pipette 1
5 min Ethanol 70%, then remove with pipette 2
3 min Ethanol 50%, then remove with pipette 2
3 min Ethanol 30%, then remove with pipette 2
3 min Aqua dest, change 3 times with pipette 3
10 min Etzold Staining Solution, apply heat (50° C), then remove with pipette 3. Use 10 drops of the staining solution so the sections are covered with the staining solution.
Use Aqua dest. to rinse of excess staining solutions, remove with pipette 3
10 sec Isopropyl pure, remove with pipette 4
2 min Isopropyl pure, remove with pipette 4
5 min Isopropyl pure, remove with pipette 4
Isopropyl pure
Now use a Stereo Microscope or something similar to find the best samples and put them with a fine brush onto a freshly cleaned slide. Put a drop of Euparal on it and a cover glas. Apply some pressure (careful!).
Now bake at 40° C for 48 hours. Voila, we are done. If you did everything correct the result will look like this:
English Yew, Taxus baccata
Give it a try and show your results. It is nowhere as difficult as it sounds (even I can do it) and a lot of fun once you mastered it.
Questions are always welcome and if you need help obtaining the Etzold Staining Solution, please drop me a Message and I will help.
Good luck!
Isopropyl pure
Ethanol 70%
Ethanol 50%
Ethanol 30%
Aqua dest.
Euparal
Pipette: 4x
Watch Glas
Isopropyl pure
Good luck!
And a not-so-simple question...
You mention that "Water in the Isopropyl will remove the Chrysoidine."
In the procedure, it looks to me that the staining step occurs just before rinsing with water, after which we switch to several changes of pure isopropyl.
So I am confused. I understand that if the isopropyl has any water in it, that will fog the Euparal. But I don't understand why water in the isopropyl would affect the chrysoidine, since staining is followed by a water rinse.
Can you explain in more detail what happens with the chrysoidine?
Many thanks for writing this description! It is very clear. I am only confused on this one small point.
Ecki: Thanks, very nice explanation of the methodology.
ChrisR: In Canada Isopropyl Alcohol is readily available as "Rubbing Alcohol"
Euparal is one of several mounting media. I have used it in the past only once or twice. Its odour gives me a terrible migrane headache almost immediately on opening the bottle. I simply cannot use it. I guess there is no way you can predict how anyone will react to Euparal.
One advantage of Euparal is that it is miscible with alcohol. Most of the other mounting media will not mix with alcohol and so you have to go through a Xylene wash before mounting.
Things may have changed as it has been many years since I made permanent mounts.
Rik: Standard practice is (or was) to overstain the subject and then control the destaining under a scope to decide how much intensity you want. So perhaps you overstain with the Etzold soln and then control the final intensity with water washes. You stop the destaining with pure alcohol; but if there is water in the alcohol then some destaining will continue.
But let's wait and see what Ecki has to say.
NU.
student of entomology
Oliver Wendell Holmes, Sr
Yes Rik, Aqua dest. is high quality distilled water.
The pigments for this staining are solved in water. Rinsing with water will remove any excess staining solution that is not bound to the cells. The rinsing takes 10 seconds.
If you have some water in the Isopropyl you will see red color rising from the cuts. Quickly remove the Isopropyl and apply fresh Isopropyl. Euparal is indeed miscible with alcohol. While the Euparal "bakes" the Isopropyl gases out. If there was some water in the Isopropyl the Red will get pale in a couple of weeks.
In Germany it is difficult to obtain the chemicals, too. There are many solutions, from finding a pharmacy that understands the need of a microscopist to joining a microscopic society.
Best regards,
Ecki
Best regards,
Ecki
Brunel sells several chemicals:ChrisR wrote:This is beautiful, Ekhard.
As far as I know though, chemicals like ethanol, isopropyl alcohol, glacial acetic acid, would not be available to individuals in the UK.
HERE
NU.
Thanks, Ecki -- I understand now.Ecki wrote:Rinsing with water will remove any excess staining solution that is not bound to the cells. The rinsing takes 10 seconds.
This staining technique delivers the following result:
Woody cell-walls: red. Often the colors vary, sclerenchyma purple, xylem more brick-red or yellow red. The chrysoidine reacts with lignin, the protein that makes cell-walls woody.
Cutin cell-walls: yellow to orange, sometimes red
Cell-walls without cutin or lignin: green
Cork: colorless, but middle lamellae red as they are woody
Plasma: light red
This staining was developed by Dr. Helmut Etzold. It differentiates the different cell types well and can be used as a mixture - thus making the staining process pretty easy.
To produce the staining solution solve in 1 liter distilled water:
Glacial Acid = 20 ml
Astra Blue = 1,25g
Fuchsine = 0,1g
Chrysoidine = 0,143g
Plasma: light red
Astra Blue = 1,25g
Fuchsine = 0,1g
This is slightly off topic but might be of interest:
http://www.microscopy-uk.org.uk/mag/ind ... mount.html
As might this:
http://www.nhm.ac.uk/hosted_sites/queke ... links.html
Harold
As might this:
Harold
