Trying to find best combination of Pentax and Nikkor lenses
Iainp
Post by Iainp »
Ok, I've got to grips with the basics of photography through a microscope, now I need to take things to the next level with camera and lenses. My El-Nikkor 1:2.8 arrived yesterday, and my bellows are due to arrive any time now. In the meantime, my dad's given me his old Pentax lenses to play with, and I've spent the morning experimenting with every combination of camera, extension tubes and lens I can think of.
Here's what I have:
Tamron 70-300mm Tele/Macro
Tamron 90mm 1:1 Macro
Nikkor 18-55mm 1:3.5 - 5.6
EL- Nikkor 50mm 1:2.8
SMC Pentax-A Zoom 1:4 70-210mm
SMC Pentax-A 1:1.7 50mm
Pentax-A Zoom 1:3.5 28-80mm
Fujinon 1:2.2 55mm
Extension tubes
The problem: I don't have any reversing rings or any other connectors.
The solution: Duct tape!
What you are seeing here is Nikon D60 + tubes + 70-200mm lens + reversed Pentax 50mm with homemade snoot (Extra foil needed to extend its range beyond the 90mm Macro it was designed for)
Here are some of the results for various combinations. The subject is a very dilapidated Small Tortoiseshell Butterfly wing.
With set up as per photo, with lens at 70mm (1/9th crop of original)
Now with the Tamron 90mm Macro + EL Nikkor ((1/9th crop)
There seems to be a real problem with CA around the scales. Could this be anything to do with the design of the Tamron lens? I read that the 2 lenses should be as close as possible to each other when reverse mounting, but that's not possible with the Tamron 90mm because the lens is so far back in the casing:
So far, I haven't managed to get any decent results with the EL-Nikkor in any of the combinations.
The best images so far have come from reversing the Fujinon onto the Macro 90mm.
(1/9th crop)
With the Fujinon 50mm reversed onto the Tamron Zoom at 300mm, things really start to fall apart:
Has anyone got any suggestions as to what other combinations to try, and ideas on why things may not be working in the above setups?
Re: Trying to find best combination of Pentax and Nikkor len
Iainp wrote:Has anyone got any suggestions as to what other combinations to try, and ideas on why things may not be working in the above setups?
You didn't mention what may be the most important aspect of each combination: which lens did you stop down?
To get the best quality at high magnification, you should be stopping down the front lens. It is usually more convenient to stop down the rear lens, but that practically guarantees that the light rays forming the image have been selected from the worst sections of the front lens.
In theory, it shouldn't make much difference smack in the center of the image, but away from center, it can make a huge difference. The very best position to place an aperture (in terms of image quality) is usually between the two lens, but that's also the place of least convenience. Stopping down the front lens is not optimal, but it's more practical.
As for other combinations to try, this will sound a bit facetious but since you have the lenses in hand, try 'em all! If that would be too troublesome, try this rule of thumb. For the front lens, avoid zooms. For the rear lens, stop down and look into the front to see where the aperture appears to be. The closer it appears to the front of the lens, the better.
Remember also that every one of those front lenses will have an optimum aperture. Usually that's a couple of stops below wide open, but you might have to search for it.
Hope this helps, and looking forward to the next report.
NikonUser
Post by NikonUser »
I have never heard of anyone stacking a 50/2.8 El Nikkor onto another lens.
This lens seems to work OK, reversed, all by itself. But of course needs some/a lot of extension.
This moth was with a reversed 50/2.8 El Nikkor @ f/6.7 (not 1/2 stop < f/5.6 as stated) but don't remember the amount of extension:
HERE.
British Small Tortoiseshell butterfly wing scales seem to be a bit smaller than the scales on that moth's thorax.
This is what your reversed 50/2.8 El Nikkor @ f/6.7 on 22cm extension should give you with a Small Tortoisehell's wing. Those blue scales really scatter the light.
Not the best lens for wing scales.
Top: full frame of 4,288 px wide
Bottom: 1200 px selection (to get orange & blue scales in frame) reduced to 800px
NU09212 NU09213
NU.
student of entomology
Oliver Wendell Holmes, Sr
Iainp
Post by Iainp »
Where's the "embarrassed" emoticon? Ah there it is :oops:
Rik, I had all the lenses on max open aperture. With all my comparative testing, that's the one factor I didn't adjust at all. I'd assumed the more light the better.
Ah well, that will keep me busy this morning.
NU: I need that emoticon again :oops: Despite having read around the subject on the forums, I'd come away with the idea that lenses always needed to be reversed onto other lenses...
I look forward to my bellows arriving so I can give it a go properly. If my final result looks anything like yours I will be VERY happy.
NikonUser
Post by NikonUser »
Try using your Tamron 90mm macro, non-reversed, on a bellows or black vinyl pipe.
Try f/8 on the lens and with the lens at its full extenion
Try different lengths of pipe, say 6" and1 foot.
Should give excellent images from about 1x-5x, perhaps even greater
See what my 105 macro does for me:
SCROLL DOWN TO PAGE BOTTOM
NU.
Iainp
Post by Iainp »
Lovely shot. I'm really glad you mention the Tamron Macro: when it's not on the camera the aperture automatically closes down fully, so I assumed that without the electrical connections of a decent set of extension tubes, it couldn't be used with bellows etc.
I've just got the lens out again to check I haven't missed something - I'm hoping to avoid having to use the Embarrassed Emoticon 3 times in one day - but I can't see any way to over-ride this. If there is a way to open up the aperture off-camera I'd be very happy to find out how!
Iain,
I'm glad that NU thought to post that photo from EL Nikkor on bellows. I had assumed that you were playing with lens combos (short reversed in front of long) only because you wanted to get some experience with that until your bellows arrived.
Of the lenses that you have, the best image quality will probably come from the EL- Nikkor 50mm 1:2.8 reversed on extension. That lens has a manual aperture, so duct tape and tubing will work fine for extension. (Do check for reflections from the inside of the tube. They can cut your contrast quite badly.)
The main reasons for using a lens combo are that:
1. Combos are the only way to get high mag macro using a camera with a non-removable lens. Think point-and-shoot, or "DSLR-like" (e.g. Panasonic DMC-FZ50), or a camcorder.
2. Combos gives high mag macro using only stuff that many photographers already have in their bags.
3. Combos have some practical advantages for field use:
3a. They're relatively durable, compared to bellows.
3b. They provide automatic stop-down at the instant of exposure, if you choose to set aperture using the rear lens.
Notice that quality of image is not mentioned in this list. There are a few combos that happen to give top-notch results, but this is a matter of luck and accident since the lenses were not designed to work together. In most cases, the image quality of a combo will be nowhere near what you can get with a good enlarging lens or a designed-for-macro lens reversed by itself on extension.
The purpose of reversing a lens, either by itself or as part of a combo, is to minimize aberrations by placing the lens and its two conjugate image planes (e.g., subject and sensor) in the relationship for which the lens was designed. In most cases, that means with the short distance on the mount side of the lens. In some cases, notably with microscope objectives and "bellows macro lenses", the lenses were designed to be used non-reversed, with the short distance on the front of the lens; reversing those will degrade the image.
NikonUser
Post by NikonUser »
Iain:
Your 50mm Pentax when reversed on extension, and by itself, should give excellent results
I have an old 50mm Canon that I sometimes use reversed on a 105mm and a 200mm. It gives a good/excellent image.
So I tried it alone reversed on bellows. These are single frames, quick and dirty using a plastic ruler, to show the potential for your 50mm Pentax.
I'm 100% certain that with care this single lens reversed would give excellent images.
NU09214
NU.
Iainp
Post by Iainp »
NU: that's a great demo.
Rik: in just a few short lines you've answered several questions that I had wondered about. When I started looking at the macro forum a few months back and saw all those descriptions of bellows/lenses/reversed lenses etc, my first question was "What?" (are they doing) followed quickly by "Who?" ( can explain all of this to me) then I got to grips with "How?" are they doing it, then "Where?" (can I get this stuff!) and now I've got some idea of "Why" (people choose particular setups)
I look forward to repaying all this help by posting some outstanding images soon :)
Iain, you're very welcome.
Regarding NU's use of the old Canon lens, I have had similar experience with an old Mamiya-Sekor 55 mm f/1.8. Until a few years ago, the Mamiya-Sekor on bellows was my favorite setup. But be very careful to determine what apertures work well. Wide open will probably be awful. Stopping down to f/5.6 or so will make a huge improvement. See HERE, second image, second column.
You'll be needing reversing adaptors and the like as well.
The far-eastern ones are so much cheaper than camera manufacturer's, it has to be the way to go, but the quality does vary. I had to replace one, because it was too sloppy and thin. A "Roxsen" turned out to be far better, and about the same price.
If you obtain one reversing ring for whatever's a common filter thread for your lenses and your camera , say for Nikon, 52mm, you can then get step rings to go from 52 to whatever you need.
In a mo I'll edit this to tell you what you need for an El-Nikkor...
Iainp
Post by Iainp »
Ta, very useful link, though I've just been on a long journey round the forum as one link enticed me into another:
"macro lens shade" I'll be trying out one of those tonight
"There's also a significant shift in focus point over the first couple of f/stops, so it's a bad idea...to focus wide open and then stop down to shoot" That's something that wouldn't have occurred to me.
Post by Planapo »
The EL-Nikkor 2.8/50 N has a 40.5 mm filter front thread, so on one side of the reversing ring/adapter you'll need this size as a "male" thread. Don't know about the earlier "non-N" version.
Sorry, Chris for my post inbetween, but your "mo" lasted 20 min, so I'd thought you'd got distracted. :wink:
--Betty :D
WHy do I have to keep logging in...? :evil:
Anyway the El-Nikkor 50/2.8, and 63/2.8 are 40.5mm filter thread.
Edit
Ah! She beat me. :P
If you use a 52mm reversing adapter, that'll have a 52mm male, so a standard 40.5 to 52 will be right. Ie as if a 52mm filter would go on a 40.5 lens.
Oh - and use a "lens hood" on what becomes the object side of the lens. Eg a black paper snoot as Rik shows, or a 39mm tube, which is stronger.
You thought right! That's the trouble with this forum! :D
