Chironomid midge of some kind - a biggie I think, body around 10mm long. Still quite a small head though...
81 images shot with Nikon 10x/0.30 CF Plan objective stacked with Zerene stacker (Pmax).
Chironomid Midge
Thanks!
This thread was nearly titled 'ode to Charles' or something similar!
To be honest there aren't many angles from which you can see the interestingness of the front of the face with these beasties (The antennae are so big and feathery they just get in the way from any other angle I tried!)
Chris the subject is 'mounted' on a piece of sandpaper about 2cm by 1cm, folded in half and allowed to spring back open a bit (say very roughly 45 degrees), then one end is stuck up between the subjects wings and body. Hope that makes sense, let me know if not! (I initially used a piece of white card but could not achieve a decent exposure with that so close to the subject, this is still a little 'hot' in the bottom corners..)
I tried with supergluing midges a couple of times - it seemed to gunk up the antennae as it fumed.ChrisR wrote:I look forward to being able to repeat this sincerest form of flattery!
Even at 10mm long, there's not a lot of body to pin. Is that what you did, or is it a mass of super-glue back there?
Andrew
