T-mount cap / blank ?
Anyone know of a source for a T-mount cap ? Basically I want to make some test mounts for some lenses to fit onto a T-mount.
I want the equivalent of a camera body cap so I can drill an appropriate hole and mount the lenses on the cap
Andrew
Andrew
- Charles Krebs
That would be nice wouldn't it. But I've never seen one. Pieces with male T-threads are not that common.
Although it's a kludge, if the lens is really light weight you can often get by with a cheap Pentax (M42) T-mount. Although the thread pitch is different (1.0 vs 0.75) the cheap M42 T-mounts can screw in quite a ways before things "snug up". Put a disk with the appropriate size hole on the front. You can epoxy the disk on. Better yet you could remove the T-threaded insert (via the three set screws) and insert in it's place an appropriately sized disk with the proper hole size.
Edmund Optics (among others) sells short T-mount extension tubes and adapters with male T-threads on each side. Either of these can be adapted for this purpose if you want a proper male T-thread to work with.
Another option is to make up a male T-thread to, say, a 52mm (female) filter thread adapter. Then you can use readily available (an inexpensive) metal screw in lens caps.
One of the ebay step-up/down adaptor sellers does one with a 42/0.75 Tmount male thread, stepped from normal filter sizes. I'll post a link if I find it again.
I've recently bought some of the cheap Chinese extension tubes which have screw connections in the middle. I believe they're 55mm, but not sure if they're the same pitch as a 55mm filter, - I have none that size.
Edit sorry 57mm, as best I can measure.
SRB look useful but they are a bit expensive for some of their bits.
This ebay seller:- "heavystar "
sells a variety of cheaper "stack caps", ie metal caps with male/female threads, also body caps.
A T2 female thread is 42 x 0.75 iirc, whereas the old Pentax/Praktica camera mount was 42 x 1. In practice by the time the thread has jammed, if you use the wrong pitch, it's a turn or so in, and gripping well enough.
(Edit Sorry, Charles had already written this )
It's quite possible that a 39 or 42mm cap pair would go into the T2 mount in place of the rotating collar and suit your purpose?
I can confirm that from experience with T-Mounts incorrectly sold as M42 adapters. This is a problem where infinity focus is required, but not for close-up/macro.ChrisR wrote:In practice by the time the thread has jammed, if you use the wrong pitch, it's a turn or so in, and gripping well enough.
Harold
But these are only GBP1 each 370224189639
I'm sure they won't be as secure lock onto the bellows as a screw fit, but for something sacrifical to drill holes in and mount odd fitting lens, seems a good way forward.
If I can find a T-mount to filter adapter with the right hole size that would be nice.
Andrew
Andrew
What "right hole size"?
I'm sure we've all done it, Andrew, I have a cone cutter for the purpose. Double sided thin tape comes in useful too .
I reckecked the Chinese Extension tubes. The threads appear to be 57mm x 0.72mm, as best I can measure. That's probably 57 x 0.75. Is that the same as 57mm filter?
If so, though a bit unusual, with more adapters it would give a cheap screw connection between different lenses and bodies.
- Charles Krebs
