These have been dropping like, well, like flys in our heat wave
It is a 4 frame pano with approximately 150 images in each of the frames.
Here's a 100% crop that shows its incredible invisible legs. I was lucky to get the image before it disappeared altogether
Olympus e330
El-Nikkor 60mm
f/5.6
Approximately 2.5X
Stacked with Zerene Stacker
Stitched with Microsoft ICE
The flip side
I would expect other focus stacking programs to have even more trouble stacking this one. There's just enough distance between the legs that portions of the back leg are equally as sharp as the front leg where they overlap. I'm not sure why the algorithym picks one over the other. Running the stack backwards didn't help. I expect the easiest way to fix it would be to run separate stacks for each leg.ChrisR wrote:Love the detail, and the macabre mood, though I'd like to see more shadow detail.
When Rik adds "lighten" and "darken" modes to his retouch tool the legs will be easier to untangle!
ELNik 60mm?
I'll have to download the latest version, he may have already added the feature
Nope, no changes in that area for the new version.elf wrote:I'll have to download the latest version, he may have already added the feature
The best way at present to fix up transparent foreground is to use the "stack selected" feature to render the foreground things by themselves, then use the retouching tool to merge those portions into the full stack.
For PMax, selection of detail from one frame over another is done strictly on the basis of local contrast. Order doesn't matter.
Nice image -- very dark and macabre!
