Recommendations for a lens to give about 6x on bellows ..
Anyone care to recommend a lens for roughly 6x mag on a bellows / tube ? I keep wanting something between my El-Nik 50mm and my Nikon 10x objective.
Thanks, Andrew
Thanks, Andrew
This one I expect:
http://www.alanwood.net/photography/oly ... 38-28.html
More like £600. I had mine stolen and had to replace it last year.lauriek wrote: Yes these days they go for 3-400 pounds usually, sometimes more...
With that lens, you will pay a premium for the automatic diaphragm, which you can't use in your set-up. The manual version is more often available and sometimes less than half the price:
http://www.alanwood.net/photography/oly ... 38-35.html
Harold
Harold, do you have any data on how the two versions of that OM lens compare?
People occasionally ask me, but I only have the f/2.8.
The optical designs are different -- 5 elements versus 6 elements. My f/2.8 performs best wide open, almost as good at f/4, and noticeably softer at f/5.6. I'm a little worried that the f/3.5 will have the same pattern, but starting at its smaller aperture. If that's true, then the f/3.5 would have somewhat lower resolution for stacking applications.
Worries don't mean much, of course, so I'd really appreciate some data if it's available.
If you frequent the 'bay and don't mind waiting a few weeks you ought to be able to get one for < £400 (I think I paid about £350 for mine a few months back), but I concede that's still not particularly cheap.
The auto diaphragm is a nice touch on an OM bellows.
I can't compare directly, but my experience of the older 20mm/3.5 olympus bellows lens (with the RMS mount) wasn't particularly good, the aperture is simply not fast enough for the magnification it achieves on 4/3 (or I would guess APS) sensors. However with the 38mm with less magnification the f3.5 version may be okay, and is certainly cheaper...
I just remembered something, search the forum here for "apo componon" and look at NikonUser's posts about the 40mm.
- Charles Krebs
Whatever you consider, f4 (marked) would be about the smallest aperture to use at 6:1 before resolution losses become too large.
Certainly the 38/2.8 Olympus is a prime contender.
If you want a little more "budget"... keep an eye out for a 28/4 or 35/4 Schneider Componon.
The 40/2.8 Apo Componon HM is also superb. But they are no bargain. However Adorama has sold quite a few on Ebay that were mounted in a "fixed" f2.8 barrel. These sold for a much more modest price. Perhaps they has more sitting on a shelf somewhere.
I am unaware of any comparisons. I found it difficult enough to find brochure or booklets including the later ones, let alone all four.rjlittlefield wrote:Harold, do you have any data on how the two versions of that OM lens compare?
There may be something useful here:
http://www.mir.com.my/rb/photography/ha ... tm#38mmf28
http://olympus.dementia.org/eSIF/om-sif/lensgroup.htm
The forum to search is:
http://photo.net/olympus-camera-forum/
Harold
My local high street photo shop, surprisingly, has the 20/2 for GBP £500. I couldn't quickly see how to use it at all on non-Olympus bellows. Doesn't it stay wide open, or is there a button to shut it?
The Manual Focus 28mm 2.8 8 element Nikkor wide angle is reported as being good, either way round. I know it's retrofocus, but aren't all those ELWD scope lenses too?
The 20mm 2.8 is supposed to be OK too, but at full aperture, reversed, its contrast is low and there's a hot spot in the middle.
There is a button, but it's a spring-loaded DOF preview, no built-in latch. On the other hand, the auto-aperture mechanism is so simple that it would take about two minutes to bend a paperclip to hold it activated. On the other other hand (a third one?), the Olympus auto bellows is not very expensive (compared to the lenses...), it does have a manual stop-down lever, and it's easily adapted to fit most cameras. If you're not happy with Olympus-to-whatever mount adapters, then take advantage of the design that the rear standard of the bellows is just a cylindrical sleeve with a holding screw run in from the side.ChrisR wrote:Doesn't it stay wide open, or is there a button to shut it?
Edit: correct word: "auto-bellows mechanism" --> "auto-aperture mechanism"
Last edited by rjlittlefield on Thu Jul 23, 2009 11:01 pm, edited 1 time in total.
