Nikon scope objectives.
Charles Krebs wrote:r = 0.61 × λ/NA seems to be more widely used and accepted
Right. That's because r = 0.61 × λ/NA gives you a feature size at which you still have contrast that's usable though small, while r = 0.5 × λ/NA (=λ/(2*NA)) gives you the feature size at which contrast disappears altogether.
As a small attempt at humor, I might say that Nikon's numbers come from a calculation that tells you the pixel size needed to minimally capture nothing at all (2 pixels per feature at 0% MTF).
On the other hand, there's another way to interpret the same calculation.
With perfect optics, the MTF is about 40% at twice the cutoff size (half the spatial frequency) and about 20% at 1.5 times the cutoff size. (See the graph HERE.)
So, Nikon's numbers also tell us the pixel size needed to give 4 pixels per feature at 40% MTF, and 3 pixels per feature at 20% MTF.
Somehow I find this second interpretation more comforting.
Rik,
If you want to get "uncomforted" plug in a 4/0.20 Plan Apo (at 1X relay magnification) and see how some camera sensors stack up :wink:
Well, I'm still comforted that the calculation produces a meaningful number.
The fact that it says I need the pixel count of a scanning back, now that's impressive!
Also impressive to compare that 4/0.20 with the requirements of a 40/0.70.
Ohhh the heavy toll of diffraction :cry:
NikonUser
Post by NikonUser »
Just sold on e bay
NIKON M PLAN 5x 0.1 MICROSCOPE OBJECTIVE
Item condition: Used
Ended: Oct 04, 200900:42:16 EDT
Bid history: 7 bids
Winning bid: US $203.50
NU.
student of entomology
Oliver Wendell Holmes, Sr
Hmm I saw that. I think I bid to about $50!
This one almost looks cheap then:
Nikon CF Plan 5x/0.13 inf/0 EPI objective BIN/offers on $199
I can't help wondering how much difference the tube length would matter...
Here
and I was surprised there were no bids on
Nikon microscope objective 4 Plan 0.1
at £6.99!
here
NikonUser
Post by NikonUser »
$50.00! that would have been a sweet deal.
That 5x you referenced is an infinity lens; no use for camera/bellows setup?
The 4x looks the old style, and not chromatic-aberration-free.
Compare it to the one I recently bought
HERE
NU.
Ah. Nearly wasted £6.99 then!
Has anyone tried it?
yes I saw the one you bought recently - I'd decided to let it go! I'm sure you'd get better images from it than me :wink:
How very odd, serendipitous.
I've been incarcerated in a British Institution for 3 days.
Not what you're thinking, it was the NHS, c/o kidney stones.
While I was away a tiny parcel came. It was a "5xcf Eyepiece" I'd bought for £12.
Wifey forgot to give it to me.
I wasn't sure I wanted an eyepiece, but I was intrigued so bought it on a hunch. CF, I thought??
WHat do you think it is...?? (sitting in a brass plumbing fitting)
NikonUser
Post by NikonUser »
In the early 1990's Nikon had a CF-E High-Eyepoint Widefield eyepiece "the standard, designed to be used with all objectives"; i.e., their CF 210mm objectives.
CF-E 5X focal length 40mm Field Number mm (width??) = 18.6. Retail (1993) US$76.00
NU.
Well at US$19 that would have been okay. But in fact , when dehisced..
I don't think I'll ask for my money back?
I'll obviously have to see if it's "any good". I have a few lenses, but specimens equipment and technique to make them all look bad though...:)
NikonUser
Post by NikonUser »
So it has metamorphosed from an eyepiece to an objective, neat trick.
It looks like a Nikon objective for their Optiphot scopes.
You must let us know how it works on a camera as it is an infinity-corrected brightfield objective.
NU.
Yes, I chortled volubly when I discovered what it was. Wifey bemused at my reaction, but hey.
Unfortunately I don't have the lens you bought recently, so I can't make a direct comparison, but I'll see if it's terrible, I suppose.
I "feel" that the difference in optics will show less at the lower magnifications, and their lower NAs, though that may be total nonsense.
Making a 40ish mm lens work well at 200mm to infinity, with such a modest aperture, doesn't sound the hardest challenge, though I don't really have much clue and am conditioned by camera lenses.
NikonUser
Post by NikonUser »
I'm confused. I thought the 'problem' was that infinity-corrected objectives need a specific eyepiece to actually form an image. This may have been covered elsewhere in the forums but I would be interested to see if you can get am image from it without using an eyepiece; i.e., camera, tube/bellows, lens.
Take a photo of a blade of grass and post it.
The lens has a WD of 22.5mm
NU.
For the record, I'm betting it'll work fine. My rationale is this graph: http://www.science-info.net/docs/etc/Tube-Length-na.gif , where the tube length tolerance for NA=0.13 is literally off the chart. So I'll be very interested to see the pictures.
