www.photomacrography.net :: View topic - Hanging on Lunch
Hanging on Lunch
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Administrator's Appreciation Gallery...Macro and Close-up Images
Dalantech
PostPosted: Thu Apr 23, 2009 12:11 am    Post subject: Hanging on Lunch Reply with quote
Solitary Bee actively feeding -gave me all of three frames.
Tech specs: Canon 40D (F13, 1/250, ISO 100) + a Canon MPE-65mm macro lens (@1x) + a diffused MT-24EX macro twin flash (-2/3 FEC).
Link to a larger version -just click on the link to expand it. I also blogged about this, and a few other photos, in a post called Difficulty and Deception.
My Gallery
My Blog
Macro Tutorials
augusthouse
PostPosted: Thu Apr 23, 2009 2:39 am    Post subject: Reply with quote
John,
Fascinating series of images.
You've outlined the technique for this series on your blog; but for the benefit of viewers who don't happen to click through; could you briefly summarise the use of the flash as your shutter aspect?
Dalantech
PostPosted: Thu Apr 23, 2009 4:31 am    Post subject: Reply with quote
Excellent question Craig!
Kinda tough to sum it up in just a few words though.
At life size magnification, F11, ISO 100, and 1/250 of a second for the shutter there is very little natural light getting though the lens and onto the image plane (the sensor in the camera). If the flash does not fire, then the resulting image is going to be almost completely black -only the most reflective objects in the scene are going to get recorded (barely). At higher magnifications the image will be totally black if the flash doesn't fire.
Since the flash is the only significant light source being recorded by the camera it becomes a "virtual shutter" and the short duration of that light can be used to freeze motion. We've all seen images of a balloon in mid pop, frozen in time by a short burst of light from a flash (if you haven't then look here). The same principles that apply to high speed stop motion photography, freezing motion with a flash, apply to macro -IMHO macro is just one form of stop motion photography.
In my experience the shorter the duration of the flash the sharper a macro image will be. So getting the flash close to the subject, and using a good diffuser (one that actually diffuses the light and not just block it) is key to getting high quality macro photos.
If you'd like, in another thread, we can get into the difference between diffraction and what I call "macro motion blur" induced by a flash duration that's too long to freeze the motion in a scene.
My Gallery
My Blog
Macro Tutorials
augusthouse
PostPosted: Thu Apr 23, 2009 5:33 am    Post subject: Reply with quote
Dalantech wrote:
Yes Please!
gpmatthews
PostPosted: Thu Apr 23, 2009 6:19 am    Post subject: Reply with quote
This is pretty much how flash photomicrography works - I use continuous illumination that is adequate for manual viewing, but will produce a black field at the camera settings used with flash, if the flash is not fired. Hence the flash duration governs the exposure time.
Graham
Dalantech
PostPosted: Thu Apr 23, 2009 12:23 pm    Post subject: Reply with quote
Will do Craig -what forum do you want it in?
My Gallery
My Blog
Macro Tutorials
PostPosted: Thu Apr 23, 2009 2:44 pm    Post subject: Reply with quote
Macro and Micro Technique and Technical Discussions
Dalantech
PostPosted: Fri Apr 24, 2009 2:12 am    Post subject: Reply with quote
Done Smile
My Gallery
My Blog
Macro Tutorials
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Administrator's Appreciation Gallery...Macro and Close-up Images All times are GMT - 7 Hours
