www.photomacrography.net :: View topic - Cuckoo bee (Paper vs foam diffuser test)
lauriek
PostPosted: Tue Apr 14, 2009 1:11 pm    Post subject: Cuckoo bee (Paper vs foam diffuser test) Reply with quote
Cuckoo Bee (Nomada sp.) Please let me know if you don't think this is right, I'm not certain on this one, though I'm pretty sure it's a solitary bee of some kind, it has feathery hairs...
The usual setup, OM38/2.8 @ f2.8, 48 images stacked in ZS
Here's a side on shot;
same setup, 48 images stacked in ZS
Flickr | www.laurieknight.net | Blog
lauriek
PostPosted: Wed Apr 15, 2009 3:05 am    Post subject: Reply with quote
Incidentally I've been doing a few tests, the shots above were with a paper diffuser. The following shot is framed almost identically to the first shot above but was using a foam diffuser...
At web size I think this shot looks better, but at full resolution, more detail is definitely visible in the hairy sections in the first shot. However I think the less diffuse light in this shot gives more definition to the bits of the compound eyes.
It seems like everything in photography, diffusion is a real balancing act!
PostPosted: Wed Apr 15, 2009 7:17 am    Post subject: Reply with quote
Absolutely.
Using paper diffusers and a fiber illuminator, what I find myself doing is adjusting the distance between the fiber bundle and the paper.
This changes the size of the virtual light source, so I can dial in anything from the diameter of the bundle up to a most of a hemisphere, or a combination of those by using two bundles.
This idea is of course cribbed from Charlie Krebs' notes.
Nice illustration!
kds315*
PostPosted: Sat Apr 18, 2009 12:07 pm    Post subject: Reply with quote
I like the "foam diffusor shot" better, since it brings a higher contrast all over and a few nice highlights.
Which foam did you use??
Klaus
lauriek
PostPosted: Sat Apr 18, 2009 4:05 pm    Post subject: Reply with quote
Klaus,
It's that thin white foam you get wrapped round all sorts of electronics these days. I think the best bit I have was wrapped around an LCD monitor...
