I can't find any sources for these. Have they "gone"?
I know they don't take you into very small territory but I used single element close up lenses on telephoto lenses years ago, which were just about OK. I assume the doublet ones would be a worthwhile improvement.
The s/h vendors don't seem to have the T-series either.
edit - I found just two 62mm on ebay , item 400040458215
5T 62mm $129
400040464795 6T, $139
On a 70 - 200 ish zoom would I be better off in terms of IQ using say Kenko's auto tubes?
I realise zooming would probably shift the focus.
info: http://www.dslreports.com/shownews/68725
Nikon T-series close up lenses
Yeah I think Nikon stopped making these a couple of years ago. I wondered if the value of mine might go up over time! (I've got a 5T and a 6T with 62mm threads)
The Canon 500D is another option, and Raynox also make some good doublet diopters.
On a longish tele-zoom you would be marginally better off in IQ terms using tubes, but a diopter will likely give more magnification. (You need a lot of tubes to get any real magnification with a long lens, 70mm of extension for 1:1 at 70mm focal length, 200mm of extension for 1:1 at 200mm). Increasing the amount of glass generally decreases the quality, so although these are _good_ diopters, they will marginally affect quality where a tube will not (unless you push diffraction limits).
However a diopter will give you more magnification on a longer lens whereas tubes give more magnification with shorter lenses...
Good diopters are certainly worth having in the bag if you have a good long tele, but personally I generally prefer tubes.
That is correct. Nikon does not support their extension tubes any longer (for quite a long time),
and they stopped making the 3T, 4T, 5T and 6T achromats 2 years ago.
(at that time I got a 6T from Nikon for €68.00, so they definitely go up in price; hard to find on ebay)
However Nikon still suppports their teleconvertors (TC-14Eii, TC-17E11 and TC-20Eii) for use on their latest models of macro lenses.
It is explicitly mentioned in my 105mm f/2.8 VR macro lens manual.
I would not use the TC-20 but with the TC17-Eii maximum magnification is 1.7x.
Oh, and these teleconvertors do fit on the new macro lenses.
-Jan-
Think it was around 2006 when Nikon stopped producing them. Here are details of the lenses:-
http://www.mir.com.my/rb/photography/ha ... ndex3a.htm
Do try EBAY though since I obtained my 6T from the USA through EBAY as they sell on US EBAY for a lot less than on UK EBAY, so even with postage from USA to UK it was still cheaper. I also got my full set of Nikon extension tubes one by one off EBAY from the UK, USA and Germany!
You can do a search on EBAY and if it comes up blank record that search and EBAY will automatically send you an alerting e-mail if anybody posts one for sale later.
DaveW
DaveW
Hhmmm...
"Increasing the amount of glass generally decreases the quality, so although these are _good_ diopters, they will marginally affect quality where a tube will not (unless you push diffraction limits)."
"For adding a small amount of magnification, a good add-on macro is better than an extension tube."
I've had good and not-so-good results both ways. The problem with tubes is that they take the main lens outside its design space, which causes aberrations to appear. Add-on lenses leave the main lens inside its design space, but add their own aberrations.
The result, I think, depends on which way the balance goes for the particular lenses in hand.
