Twig and Lichen Deep Zoom
Here's a little (900 image) focus stacked macro panorama of lichens on a twig. It was stitched with Microsoft ICE and is a 4x4 matrix and is around 80 megapixels. It's in Deep Zoom format and requires Silverlight 2 to run (Sorry Mac users).
The twig is 2.6mm in diameter and 46mm long.
http://www.efrench.members.winisp.net/t ... ichen.html
Well, more accurately, my super macro to infinity spherical and orthogonic panorama and lenticular head with geared movementsrjlittlefield wrote:Looks great -- even runs under FireFox.
Is this shot with your rotate-around-the-entrance-pupil macro head?
Yes, it was shot by rotating around the entrance pupil. This type of image was what led me to add the bellows to the spherical pano head. It allows the lens to remain fixed while the focus point changes. There is no parallax errors between frames. Well, I should say the amount of parallax error is so small that it doesn't matter.
The lens was the El-Nikkor 50mm 2.0 reversed at f/5.6
- augusthouse
"Deep zoom" - any reason why you used this instead of Zoomify ?
http://www.zoomify.com/express.htm[/url]
Craig: Thanks and yes, the Ott-Lite was used.
Andrew: I've used Zoomify in the past, but the file sizes were way to large to post. I only had room for one from my Internet provider. This Deep Zoom is only using about 7mb of space. The second reason is ICE is my panorama stitcher of choice. It can handle 95% of the stitching I do. When it can't do a stitch, I'll use PTAssembler.
Cyclops: A good reason to use IE Hopefully Silverlight will support more platforms in the future.
Ah the laptop uses IE but my phone either uses its own browser or OperaMini which I downloaded for it because the phone's internal browser is incredibly slow.
So for the same size source, Deep Zoom has much smaller output ? I looked at it a few months ago but it seemed really clunky to use (with zoomify you just drag the original onto a zoomify icon and away it goes). Has Deep Zoom got easier to use ?elf wrote: Andrew: I've used Zoomify in the past, but the file sizes were way to large to post. I only had room for one from my Internet provider. This Deep Zoom is only using about 7mb of space. .
Andrew
Yes, you have to install the Silverlight viewer. See http://www.microsoft.com/Silverlight/ .Planapo wrote: I would like to look at it, but all I see is a pitch-black window under Firefox .
Does it need any extra software/add-ons?
--Betty
- Planapo
Thanks Rik!
When go to the site you gave the link to and further click "Installieren" (I am automatically forwarded to a German language version of this site), I get the message that the needed Version Silverlight 1 GDR 3 (1.0.30401.0) is already installed.
Nonetheless, still only a pitch-black window opens when I click the link to elf's photo.
--Betty
--Betty
Hmm, Silverlight 2 is what you need. Apparently you already have Silverlight 1 installed, and the installer is willing to say "Good enough!". When I tested the link, it said that Silverlight 2 was installed, so I assumed that all was well. Perhaps a search on "Silverlight 2" will find a more hardcore installer.
This is only 16 frames, medium is 30 to 60, large is >100Planapo wrote:Jeez, how long did it take you to finish this one? And what would you call big then?
Andrew: Deep Zooms can be created from the command line using the HDMake utility:
http://research.microsoft.com/en-us/um/ ... HDMake.htm
hdmake –src <source image> –xmldeepzoom <output file name>.xml
