Well, it's Laurie's fault .... whenever I see pictures of these I just want to get out my specimens and take a few more.
Top image is moderate crop from a 5X (microscope objective) shot. Lower two were with the 20X Nikon CF M Plan. Half a "whiffle-ball" was used as a diffuser for the top shot. Half a ping-pond ball was used as a diffuser for the lower two.
Although the highly iridescent, multicolored scales attract the most attention, there are many gorgeous areas on these wings that do not show this phenomenon. The center image is taken along an edge of the wing.
Still more Sunset Moth!
- Charles Krebs
- Charles Krebs
Larry,
http://mdwiffle.net/2008/10/25/welcome- ... ffle-ball/
With some subjects, a really diffuse light works well to help avoid "hot spots", so I use a translucent hemisphere with a hole cut into it for the lens. You can see one used here:
http://www.photomacrography.net/forum/v ... php?t=2825
The light is directed through the translucent hemisphere and the iridescent wing scales really show their colors!
It's a white plastic baseball that has holes on one hemisphere and is solid on the other:Now,whats a whiffle ball?
Cyclops wrote:Beautiful shots MrK!(that Laurie has a lot to answer for )
Now,whats a whiffle ball?[/quote]
Plastic, baseball size balls, that have holes in them. So that when you hit them, they do not travel as far nor do they hurt you if you get hit by one. Haven't seen one in years though.
Great shots here Charlie. I need to visit over here more often and take in some of the color. Winter is or has been getting me down.
my god theres a whole society devoted to these things!Charles Krebs wrote:Larry,It's a white plastic baseball that has holes on one hemisphere and is solid on the other:Now,whats a whiffle ball?
