| Author |
Message |
rjlittlefield Site Admin
Joined: 01 Aug 2006 Posts: 7323 Location: Richland, Washington State, USA
Posted: Thu Mar 05, 2009 3:00 pm Post subject: Remains of a brown lacewing |
At least I think it was part of a brown lacewing.
I debated putting this one over in Nature Photography, just because I could make a case for it.
Of course you'd ordinarily see this sort of image here in Technical and Studio.
But honest-to-gosh, this one really does fit under "Images of undisturbed subjects in their natural environment".
How does that work, you ask? Like this:
Yep, sure enough, photographed using natural light, in situ, right where I found it --- stuck to the outside of a window!
I'm presuming that once upon a time this was part of a spider's meal, and now the wing is all that's left, flattened by weather against the glass.
Hope you enjoy!
Technical: Canon 300D camera, 80 mm Olympus bellows lens at f/8, 1/10 second, one frame. Photographed through two panes of glass. The block of wood braces the front of the bellows rack against the window. Otherwise the bellows was overhung so far that tripod vibrations were like a flagpole swinging in the breeze. |
| Back to top |
elf
Posted: Thu Mar 05, 2009 9:25 pm Post subject: |
| What's that cube shaped thing that looks like a sponge floating in front of the camera? |
| Back to top |
Posted: Thu Mar 05, 2009 10:47 pm Post subject: |
That's the "block of wood" mentioned in the fine print. It's there to stabilize the front of the bellows against the window. With it, rock solid. Without it, impossible even with mirror lockup.
--Rik |
| Back to top |
Joined: 05 Aug 2006 Posts: 2258 Location: North East of England
Posted: Fri Mar 06, 2009 3:44 pm Post subject: |
Very good,and original,shot Rik! _________________ Canon 10D | EOS 300 (Rebel-film) | Panasonic FZ-7 EB | Vivitar/Cosina 100mm f3.5 macro lens | EF 75-300 f4.5-5.6 USM III | EF 50 f1.8 II | Vivitar Series 1 19-35 f3.5-4.5 | Slik 88 Tripod. | My macro shots:
http://stumm47.deviantart.com/gallery/#Macro-and-Close-up |
| Back to top |
lauriek Site Admin
Joined: 25 Nov 2007 Posts: 1354 Location: South East UK
Posted: Fri Mar 06, 2009 4:32 pm Post subject: |
Nice brightfield system you have there! Good capture!  _________________ http://www.laurieknight.net/ |
| Back to top |
Joined: 30 Oct 2006 Posts: 1120 Location: Northamptonshire, England
Posted: Fri Mar 06, 2009 4:54 pm Post subject: |
Interesting image Rik and good detail too considering it was taken through a double glazed window.
It looks to me as if the bottom edge of the wing (as we look at it) has been folded over. If I'm right and you mentally unfold it, the result is a relatively fat wing that would fit quite well with your Brown Lacewing id .....and of course the venation looks about right too.
Bruce:) |
| Back to top |
Cyberspider
Joined: 31 Oct 2008 Posts: 236 Location: South-West of Germany
Posted: Fri Mar 06, 2009 5:12 pm Post subject: |
nice shot Rik and a very good reproduction scale . As you wrote/show it is an image for "Nature Photography -- Macro and Close-up"... very nice details!
Something I'm not sure: Should I buy a bellows or should I buy he M-PE 65? A bellows would be cheaper  _________________ best regards
Markus
EOS 7D, EOS 3, EOS A2E, Canon 100mm 2,8 Makro USM, Sigma 150mm 2,8 Makro HSM, Canon 100-400L IS USM, Soligor Extention Tubes, Seagull Angle Finder
"Sorry, my English is not the best I will try to become better. Please, do not hesitate to correct me to avoid misunderstandings" |
| Back to top |
lauriek Site Admin
Posted: Fri Mar 06, 2009 5:53 pm Post subject: |
| Cyberspider wrote: |
Something I'm not sure: Should I buy a bellows or should I buy he M-PE 65? A bellows would be cheaper  |
You mainly shoot outdoors don't you? I don't have an MPE (Olympus shooter) but I believe the MPE would be easier to use than a bellows in the field, and be less prone to harm (Bellows can be punctured!).
Although on the other hand, a bellows is more versatile as you can achieve a vast range of magnifications with a range of focal length lenses... (though to be honest going beyond 5:1 in the field is pretty masochistic!) _________________ http://www.laurieknight.net/ |
| Back to top |
elf
Posted: Fri Mar 06, 2009 7:10 pm Post subject: |
| rjlittlefield wrote: | That's the "block of wood" mentioned in the fine print. It's there to stabilize the front of the bellows against the window. With it, rock solid. Without it, impossible even with mirror lockup.
--Rik |
Fine print should only be used in legal documents  |
| Back to top |
Posted: Sat Mar 07, 2009 2:12 am Post subject: |
| Cyberspider wrote: | nice shot Rik and a very good reproduction scale . As you wrote/show it is an image for "Nature Photography -- Macro and Close-up"... very nice details!
I'd like the MPE too but it is phenomenally expensive! _________________ Canon 10D | EOS 300 (Rebel-film) | Panasonic FZ-7 EB | Vivitar/Cosina 100mm f3.5 macro lens | EF 75-300 f4.5-5.6 USM III | EF 50 f1.8 II | Vivitar Series 1 19-35 f3.5-4.5 | Slik 88 Tripod. | My macro shots:
| Back to top |
Posted: Sat Mar 07, 2009 10:16 am Post subject: |
Thanks for the comments, folks!
Cyclops: Well, it was just sitting there, and this crazy idea came to me...
Laurie: "Brightfield"...hhmmm...suppose I should try a "darkfield" shot too?
Bruce: I was pleasantly surprised by the lack of problems shooting through the window. There must be some softening and loss of contrast. But even at actual pixels, the image looks pretty good in Photoshop. About the folding, I agree. I tried "virtually unfolding" the wing using Photoshop layers to do the mirror & align, then manually cloned out the duplicated veins. Here's what appeared.
Cyberspider: For studio work, bellows are better because you have more options. For field work, it seems like the MP-E 65 would have huge advantages. Bellows are fragile and fiddly, and something usually moves when you stop down to shoot. I don't own an MP-E 65, by the way. At this point, I can't imagine myself shooting enough high magnification in the field to justify the expense. But the high-mag field folks do seem to like it.
elf: Ah yes, the perils of "fine print". Some of us would argue it should be outlawed in legal documents too! But I suppose then all that would happen is they'd get bigger.
--Rik |
| Back to top |
