www.photomacrography.net :: View topic - Shiny metal
Shiny metal
Goto page 1, 2  Next
PostPosted: Wed Feb 25, 2009 5:19 pm    Post subject: Shiny metal Reply with quote
Every once in a while we need a "puzzle piece". Wink
This image seems to fit the role.
Any thoughts on what this is, and how it came to be?
g4lab
PostPosted: Wed Feb 25, 2009 7:15 pm    Post subject: Reply with quote
Tungsten Filament??
augusthouse
PostPosted: Wed Feb 25, 2009 7:38 pm    Post subject: Reply with quote
It's gorgeous, whatever it is!
What is it and how did come to be in this state - or come to be? hmmm...
Hint - please. Is that molten, metallic appearence part of the object or is it a result of reflection?
Ice on a fork?
PostPosted: Wed Feb 25, 2009 9:46 pm    Post subject: Reply with quote
Everything you're looking at is shiny metal. The environment that's being reflected is a simple pattern of diffusers.
What appear to be complex shapes, really are complex shapes.
For what it's worth, the appearance at this scale looks nothing at all like what I expected based on observation by eye.
It also doesn't look much like most other pictures that I find by searching Google! Think
nto
PostPosted: Thu Feb 26, 2009 4:09 am    Post subject: Reply with quote
perhaps this is the pond, cooled air? however pleasant and light gray!
Antonio
lauriek
PostPosted: Thu Feb 26, 2009 4:54 am    Post subject: Reply with quote
My first thought was a liquid of some kind, once when I tried shooting water coming out of a tap with flash it looked not dissimilar to this, but that's been excluded, so I'm truly puzzled! Smile
It has a slightly crystalline look, but if it's metal I suppose that's hardly surprising...
A scale bar might help make the guesses a bit better! Smile
I suppose by deduction if this is metal then we're looking at very thin wires of some kind. Have you deliberately de-coloured this image to confuse us or is this natural colour?
Hairs on a wire brush, fine strands of woven copper shielding?
http://www.laurieknight.net/
Jbailey
PostPosted: Thu Feb 26, 2009 8:54 am    Post subject: Reply with quote
Could this be parts from an old electric shaver?
Jim
PostPosted: Thu Feb 26, 2009 9:12 am    Post subject: Reply with quote
Now Laurie, you know I mostly do small stuff. Wink
The first image is 0.92 mm x 0.78 mm. You're looking at a crop from a 34-frame stack shot through my usual 10X objective, focus increment 0.0005".
The color is pretty close to natural. I did de-color the final image, but only to remove some CA fringes in out-of-focus regions. Then I added back just a hint of tone to make it less stark. If you're getting an impression of polished silver, that's accurate color.
PostPosted: Thu Feb 26, 2009 9:31 am    Post subject: Reply with quote
Thanks for the guesses, folks! Keep 'em coming in -- they give me ideas for other interesting things to shoot. Very Happy
More information about the current subject...
This is part of the workings of a common device. It was fully functional and probably had a lot of useful life left until I took it apart to make the picture.
That said, it's also true that this subject looks dramatically different now than it did when it was new, roughly 1000 working hours ago.
I see at least one answer in here that's clearly on the right track. Think a bit harder and add one crucial piece of detail. Think Wink
Stevie
PostPosted: Thu Feb 26, 2009 10:21 am    Post subject: Reply with quote
A light bulb filament ? Question
Hairyduck
PostPosted: Thu Feb 26, 2009 10:55 am    Post subject: Reply with quote
looks like the grooves in a record, vinyl precord master maybe?
PostPosted: Thu Feb 26, 2009 11:09 am    Post subject: Reply with quote
For comparison, here is another part of the same object. This is about 25% less magnification, same lighting setup.
lauriek
PostPosted: Thu Feb 26, 2009 12:49 pm    Post subject: Reply with quote
So we appear to be looking at a small coil, but not small enough for a bulb filament. Is this one of those catalysts from a modern jet-flame lighter, or something like that? (which I think would make it platinum or osmium?)
PostPosted: Thu Feb 26, 2009 1:15 pm    Post subject: Reply with quote
As I understand it, the material is tungsten.
A process very much like catalysis is critical to the operation of this device, but catalysis is not its primary function.
PostPosted: Thu Feb 26, 2009 1:30 pm    Post subject: Reply with quote
Very pretty photos, Rik! Especially the first one that shows features of the crystal structure of the metal.
Is this process the tungsten-halogen cycle?
If so, then I'd say it's the filament of a halogen lamp and the crystal appearance is a result of the tungsten being redeposited onto the filament.
--Betty
Goto page 1, 2  Next
Page 1 of 2
