| Author |
Message |
rjlittlefield Site Admin
Joined: 01 Aug 2006 Posts: 7323 Location: Richland, Washington State, USA
Posted: Sun Feb 15, 2009 5:42 pm Post subject: Fresh green moss |
I am getting tired of gray skies and brown plants, so I went looking for some FRESH GREEN!
Found this nice moss in the lee of a fence, brought it inside to photograph.
The first image is almost full frame, the other two are progressively closer crops.
I always enjoy the texture of moss when I get close enough to see it. Hope you do too!
Technical: Canon 300D, EL Nikkor 50 mm f/2.8 reversed on bellows at f/8, with black paper lens shade. Subject is 11 mm in width in the first frame, about 1.4X onto the sensor. 45 frames at 0.010" spacing. Dual halogen fiber illuminator through Kleenex tissue diffuser, 0.6 sec at ISO 100. |
| Back to top |
Joined: 01 Aug 2006 Posts: 2362 Location: Issaquah, WA USA
Posted: Sun Feb 15, 2009 10:02 pm Post subject: |
| Quote: | | I am getting tired of gray skies |
Yeah, and you live on the sunny side of the state!
Mosses are one of those subjects that are nice to see at any level of magnification. The last two posts Ralf has made in the microscope section were of mosses on a "microscopic" level. And when you start looking around at a clump under the stereo scope it's pretty amazing how many creatures call it home. _________________ http://www.krebsmicro.com |
| Back to top |
Joined: 05 Aug 2006 Posts: 2258 Location: North East of England
Posted: Mon Feb 16, 2009 7:47 am Post subject: |
Very nice Rik! _________________ Canon 10D | EOS 300 (Rebel-film) | Panasonic FZ-7 EB | Vivitar/Cosina 100mm f3.5 macro lens | EF 75-300 f4.5-5.6 USM III | EF 50 f1.8 II | Vivitar Series 1 19-35 f3.5-4.5 | Slik 88 Tripod. | My macro shots:
http://stumm47.deviantart.com/gallery/#Macro-and-Close-up |
| Back to top |
Planapo Site Admin
Posted: Mon Feb 16, 2009 9:31 am Post subject: |
Very nice indeed!
Fresh and green, immediately quickens my appetite for salad somehow...
But why did you use this lens at f/8? Whereas, if I remember correctly, it is expected to perform best at f/5.6
Wait...
... as it is you Rik, I could think, the answer might be that you've quickly calculated that at this magnification, with the sensor size and pixel size of your camera, and for web presentation anyway, one won't see any difference at all, and thus you've chosen f/8 as this is sufficient, needs less frames for the stack, won't wear the camera down more than necessary and will shorten the stacking time ... Right?!
I wish I could do such calculations more quickly!
--Betty  |
| Back to top |
lauriek Site Admin
Joined: 25 Nov 2007 Posts: 1354 Location: South East UK
Posted: Mon Feb 16, 2009 10:01 am Post subject: |
I've never seen moss this close up before, this makes me want to get one 'leaf' (does moss actually have 'leaves') in front of a microscope objective!
Charlie, I was stacking some lichen yesterday that I'd brought in and I kept seeing some little blighters moving around in the background! I suspected springtails but I didn't manage to actually focus on one so I've no idea! _________________ http://www.laurieknight.net/ |
| Back to top |
Posted: Mon Feb 16, 2009 10:07 am Post subject: |
I'd have used the lens at f22 regardless and then seen the difference. _________________ Canon 10D | EOS 300 (Rebel-film) | Panasonic FZ-7 EB | Vivitar/Cosina 100mm f3.5 macro lens | EF 75-300 f4.5-5.6 USM III | EF 50 f1.8 II | Vivitar Series 1 19-35 f3.5-4.5 | Slik 88 Tripod. | My macro shots:
| Back to top |
Posted: Mon Feb 16, 2009 11:11 am Post subject: |
Thanks for the comments, folks!
Laurie, I'm with you on that "objective shot". Maybe I'll see what I can do today.
Betty, I am honored by your imagination!
But the fact is, I shot some test images at f/4, f/5.6, and f/8 and just looked at 'em. The ones at f/4 were less clear, and I couldn't tell the difference between f/5.6 and f/8. So I went with f/8 to save some time and because I speculated it might make the corners a hair better.
Then I tuned back to the forum just in time to see Charlie's advice that "You can use f8 for magnifications up to about 2.5X", so I felt better about my decision...
Normally I would use one of my Olympus bellows lenses for a shot like this. But I wanted a test/demo image shot with a more available lens, so I went with the EL Nikkor for this one.
Using my 80 mm Olympus wouldn't have made much difference in the settings. My notes for the Olympus (based on test images) say that its "sweet spot" is at f/8 for 1:1 and f/5.6 at its highest magnification of about 2.2X. All of those tests were done on a 6.3 Mpixel sensor, and "sweet spot" means the smallest aperture where I couldn't see any degradation. With a higher resolution sensor, the sweet spot might happen at a slightly larger aperture.
--Rik |
| Back to top |
Aynia
Joined: 01 May 2008 Posts: 724 Location: Europe somewhere
Posted: Mon Feb 16, 2009 11:41 am Post subject: |
I'm with Betty on this one... about the salad!!
Lovely shot(s). |
| Back to top |
