View previous topic :: View next topic |
Author |
Message |
Jason G
Posted: Thu Jan 29, 2009 4:29 pm Post subject: Hi All!!! |
Good Morning - Afternoon - Evening - Night all (Delete as applicable )
I'm new here. Well I suppose you guessed. Um... not too sure what to say... I'm new. No, said that. Um... something else, surely.
Ah. I've been into wildlife photography for about 25mths now and enjoy 'being out in the field' and logging inverts. I have recently discovered home-made macro lenses, have made one and now spend a lot of time loooking for new photographic subjects.
I think this forum is very much suited to my me!!!
I look forward to spending time here
Take care,
Jason  |
Back to top |
Joined: 05 Aug 2006 Posts: 2968 Location: North East of England
Posted: Thu Jan 29, 2009 4:42 pm Post subject: |
Hi Jason from a fellow brit. Where about in England are you? And whats this about home made macro lenses-intrigued.
I'm Larry BTW! _________________ Canon 30D | Canon IXUS 265HS | Cosina 100mm f3.5 macro | EF 75-300 f4.5-5.6 USM III | EF 50 f1.8 II | Slik 88 tripod | Apex Practicioner monocular microscope |
Back to top |
rjlittlefield Site Admin
Joined: 01 Aug 2006 Posts: 18694 Location: Richland, Washington State, USA
Posted: Thu Jan 29, 2009 4:54 pm Post subject: |
Jamie, welcome aboard!
You'll find this to be a friendly and knowledgeable community.
One of the nice features of the forum's structure is that all of the old postings are readable and searchable.
As a new member and new to macro, I suspect you'd find it helpful to "browse the stacks", so to speak.
Poke around in both recent and older postings, do some searches, and in general get a feel for what techniques other people have found useful in producing high quality images.
The camera that you're using, Fuji S5600, is well suited to the use of "snoots" for routing on-camera flash to illuminates close-up subjects. I suspect you might find that a good outlet for your creative energies.
That camera can also be used with high-quality closeup lenses and reversed camera lenses to get great pictures of small subjects. Using a basic magnifying glass as a "home-made macro lens" is briefly satisfying, but after the thrill of success wears off I suspect you'll be looking for better optics to get better pictures.
--Rik |
Back to top |
Jason G
Posted: Thu Jan 29, 2009 5:22 pm Post subject: |
Hi Larry! Yep, a fellow Brit - - the lenses are very technical. They are made of... a magnifying glass attached in front of the lens
Yes Rik, satisfying but you know me too well. The grass is always greener
Thanks for the welcome, it looks like a nice active board  |
Back to top |
Posted: Thu Jan 29, 2009 6:24 pm Post subject: |
How about telling us about your avatar?
Hovering hoverflies are not easy to shoot!
--Rik |
Back to top |
Jason G
Posted: Thu Jan 29, 2009 7:36 pm Post subject: |
No, I didn't shoot it, that would be difficult. I like them too much.
Oh, you mean that sort of shoot it!
Yes, it was the best of about 10-15 photographs. The species is E. eligans, one of the biggest - the Spring hoverfly. I don't think it's in the US. You have a favourite, hoverfly or other invert? |
Back to top |
Stevie
Posted: Fri Jan 30, 2009 1:09 am Post subject: |
Hi Jason , welcome aboard .
I tried the magnifying glass approach too years ago .
Tell me , is your magnifier made of glass or has it a acrylic lens ?
Mine was acrylic batterypowered light build in and this tiny magnifier that had double tha magnification of of the main lens .
Pretty high tech .  |
Back to top |
Aynia
Joined: 01 May 2008 Posts: 724 Location: Europe somewhere
Posted: Fri Jan 30, 2009 3:31 am Post subject: |
Hi Jason,
Looking forward to your photos!  |
Back to top |
Jason G
Posted: Fri Jan 30, 2009 4:20 am Post subject: |
Thanks Aynia
Stevie wrote: | Hi Jason , welcome aboard .
Hi Steve,
The camera has a 6cm-wide, lens casing, concealing a 310mm telephoto. The magnifier is 10cms wide, approx. 3x mag and glass. Would acrylic work better then, are you saying? |
Back to top |
Posted: Fri Jan 30, 2009 1:27 pm Post subject: |
Jason G wrote: | The camera has a 6cm-wide, lens casing, concealing a 310mm telephoto |
A technical nit... The lens is not really 310mm focal length. It is a much shorter lens that acts like a 310 mm lens would on a 35 mm camera. If you look at the front of the lens, you'll probably find the true numbers. For example this image of an S5600 says 6.3 - 63 mm. The discrepancy is because the Fuji S5600 has a small sensor, only 5.75 x 4.31 mm. That's about 1/6 as large on each axis as a piece of 35 mm film, so a lens about 1/6 as long gives the same effect.
--Rik |
Back to top |
Jason G
Posted: Fri Jan 30, 2009 1:38 pm Post subject: |
Glad you have an embarrased smiley - - I feel I'll need it a bit here...
I do actually get the equiv. bit, just forgot to write it - - however, I didn't know how that equated in the terms you gave but now do, so thanks Rik  |
Back to top |
Posted: Fri Jan 30, 2009 2:13 pm Post subject: |
Not to worry -- most of us reserve that smilie for a lot more embarrassing things than this, and still we use it quite a lot!
You've probably noticed that I'm a bit of stickler for technical accuracy.
But also you seem eager to learn, and the effects of sensor size are one place where it's very easy to get confused. The big example is DOF, where for example f/5.6 on your camera is like f/32 on a 35 mm camera. That's because for otherwise equivalent images, DOF depends on the absolute diameter of the lens opening, not its f-number. So don't feel bad that your camera only stops down to f/8, when you see other people in the forum shooting at f/22. You have to take the sensor size into account.
--Rik |
Back to top |
Jason G
Posted: Fri Jan 30, 2009 2:17 pm Post subject: |
Actually, I often have wondered. Thanks - again  |
Back to top |
