www.photomacrography.net :: View topic - An Unusual Thing Happened Here...
PostPosted: Fri Oct 06, 2006 5:13 pm    Post subject: An Unusual Thing Happened Here... Reply with quote
at least it was unusaul for me. While prowling a rather large sample of moss that was pried from a chunk of rotting wood. I focused on this Sporangium. The operculum had long since detached itself from the specimen and only the peristome remained. However, what caught my eye was a bit of movement. I assumed that one of my micro insects that I normally run across in or among the delicate strands of moss, was the reason for the movement the was inside of the sporangium. So I cranked up the power on the scope a little bit and to my surprise the peristome was opening and closing at approximately the rate of once every second or a fraction thereof. I have never seen a plant of any kind do this with the exception of those videos taken under time lapse photography. To bad this is a still image, it was amazing to observe. Smile
Sporangium of moss showing peristome and sporgenous tissue
Meiji EMZ-13TR w/Sony DSC-W5
PostPosted: Fri Oct 06, 2006 5:56 pm    Post subject: Reply with quote
This sounds like a scientific mystery to me Ken. Maybe you could have dissected the Sporangium to see if anything was inside. Very strange Shocked
PostPosted: Fri Oct 06, 2006 6:48 pm    Post subject: Reply with quote
Well maybe I could have if I had the tools to do micro-surgery with. It was quite fascinating to watch and a bit eerie too. Never seen anything like that before in a plant. Rolling Eyes Thanks Doug! Very Happy
PostPosted: Sat Oct 07, 2006 2:04 am    Post subject: Reply with quote
Interesting! Could it have been becasue of the heat of a lamp you use? Doesn't a change in humidity trigger the release of the spores? There could be some sort of mechanism in the sporangium that reacts on temperature/humidity. Just a guess. Smile
Wim
PostPosted: Sat Oct 07, 2006 4:02 am    Post subject: Reply with quote
You know I considered that Wim and you could be right. Smile If spores were being released I would not have seen them with a stereomicroscope of course. Considering heat and humidity, I was thinking that if that were the case, wouldn't the sporangiums peristome just have opened and remained open, instead of opening and closing in a cyclic pattern. Quite an odd occurance and I would not know where to begin to search for information on such an event. Smile
