www.photomacrography.net :: View topic - Fire agate
Fire agate
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Administrator's Appreciation Gallery...Macro and Close-up Images
dmillard
PostPosted: Thu Jan 01, 2009 7:05 pm    Post subject: Fire agate Reply with quote
Approx. 5mm field width, 35mm Canon Macrophoto lens,, stacked in HF
I just photographed a piece of fire agate that I've had for the last 30 years. The iridescence is caused by interference colors from the thin layers of iron oxides deposited with the quartz during the formation of the stone. The surface of this piece was a little scratched, so I cut the end off of a glass shell vial to use as an immersion chamber, and submerged the stone below some oil of anise, which has a refractive index of about 1.5, close to that of quartz.
This image was therefore taken through both the oil and the clear quartz surface to record the interior colors.
augusthouse
PostPosted: Thu Jan 01, 2009 7:23 pm    Post subject: Reply with quote
David,
Interesting subject and approach.
How 'thick' was the agate and how deep (approx.) was the oil of anise.
David wrote:
This has me particularly interested.
I've heard of a similar approach being used with amber and immersion oil and I would like to lock the technique into memory for future recall.
The explanation regarding the iridescence is also fascinating.
PostPosted: Fri Jan 02, 2009 12:02 am    Post subject: Reply with quote
David,
Gorgeous.... just a beautiful picture! Great image to start 2009!
Craig... in the "old" forums (search for "amber") are a few shots I did exactly three years ago using immersion oil and a cover slip to "improve" the imperfect surface for photography. Made a huge difference.
augusthouse
PostPosted: Fri Jan 02, 2009 12:16 am    Post subject: Reply with quote
Thanks Charlie,
It just so happens, that it was to your posts I was referring to regarding "amber and immersion oil". Mr. Green
PostPosted: Fri Jan 02, 2009 12:34 am    Post subject: Reply with quote
David, this is lovely indeed! Can you explain a bit more about the big "cells" in the picture? Is each of those cells a single crystal of quartz?
Craig, about the oil, I used a similar concept HERE, for photographing the inner workings of an LED after sanding its surfaces more-or-less smooth. My oil job was, um, a bit less sophisticated, however. Wink
Aynia
PostPosted: Fri Jan 02, 2009 2:38 am    Post subject: Reply with quote
Very lovely.
PostPosted: Fri Jan 02, 2009 4:06 am    Post subject: Reply with quote
Not sure what fire agate is but its a great shot!
Rik I just checked out that flashing LED shot of yours in that link,very cool!
Canon 30D | Canon IXUS 265HS | Cosina 100mm f3.5 macro | EF 75-300 f4.5-5.6 USM III | EF 50 f1.8 II | Slik 88 tripod | Apex Practicioner monocular microscope
View user's profile Send private message Visit poster's website MSN Messenger
dmillard
PostPosted: Fri Jan 02, 2009 6:54 am    Post subject: Reply with quote
augusthouse wrote:
David,
Thanks Craig -
The piece of fire agate sat in a chamber about 10mm high and 20mm in diameter, covered with about 1-2mm of oil, varying in depth because of the irregular convex shape of the stone. There is only a thin layer of clear quartz over the hills of opaque reflective iron oxide, since the goal of the lapidary is to remove as much of this layer as possible without cutting through the "fire". I used a glass cell to contain the stone and oil because I was unsure whether the oil would dissolve plastic (a consideration also if you are working with amber or copal resin).
I worked as a bench jeweller for about 10 years (a long time ago), and also cut many faceted gemstones during that time. Immersing the rough material in liquids having a similar refractive index permits you to see the internal inclusions and fractures, and make better choices when you cut the stone. The more closely you can match the refractive index of the liquid to that of the stone, the greater the transparency you can achieve (like an ice cube in water). I liked to use oil of anise, because the high refractive index (1.55) is close to that of quartz, it is readily available (you can now find it at many grocery stores like Whole Foods, because of its use in aromatherapy), and because it makes the house smell like a candy store. The refractive indices of many essential oils can be found on the Internet. It is imperative that you use essential oils, and not the flavorings diluted with alcohol.
You may be interested in looking at The Internal World of Gemstones, by Edward Gubelin. It has some wonderful images. It was published in 1974, and sells for high prices used, but may be available through a library.
Charles Krebs wrote:
David,
Thanks Charlie,
Your amber insects are superb! I also like the idea of using a cover glass when possible, instead of an open immersion cell, to reduce the degree of evaporation of the volatile oil, to eliminate a reflective meniscus, and to protect the front element of the lens from potential contamination.
Thanks Rik,
I liked the flashing LED! The cells are the mounds of the underlying iron oxide goethite (named after Goethe, who was an ardent mineralogist in addition to his other accomplishments) which frequently has a botyroidal, or globular, habit. Malachite (a copper carbonate) and hematite (another iron oxide) also often exhibit this form.
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Administrator's Appreciation Gallery...Macro and Close-up Images All times are GMT - 7 Hours
