My Macro setup
My Macro setup
Just thought some of you might be wondering how I get my simple shots and may be curious about the lighting arrangements.
Well....
Sometimess I may drape a thin tissue over the phone to diffuse the light a little but it does knock a lot of the light out!
Well....
Indeed it is. This is the phone in question,a Sony Ericsson W800i. It no longer gets used as a phone as the joy nub is fudged,a weakness with Sony Ericsson phones. They always wear out. But its had a good run! The camera still works on it tho and is still the best camera I've found on a phone. Its the one I used for those pics taken down my microscope.rjlittlefield wrote:Well, I have wondered a little bit about that technique of "using a cell phone as a light".
This makes it quite clear --- assuming of course that the yellow block with the light coming out of it is a cell phone!
Oh no,its my baby! Tell you what tho if it ever pups I'll send you one!DaveW wrote:Tell you what Cyclops, you keep the cellphone and I'll have the Astrophytum asterias as I lost mine a year ago!
DaveW
Do you mean attach a snoot to the phone somehow? Don't they just produce a narrow beam of light tho?elf wrote:Have you considered replacing your cell phone with a snoot? You would have a lot more control over the light.
Hmmm not sure how I'd do that. I'm not very handy if you know what i meanelf wrote:That would be cute, but I think it would work better on the 10D You can pipe the light from the pop-up flash to the end of the Vivitar macro lens with no problem.Cyclops wrote: Do you mean attach a snoot to the phone somehow?
I made mine with foam core lined with aluminum foil and a piece of plastic from a milk jug. Masking tape was used to hold it together and a rubber band to hold it on the flash. If you use white foam core the aluminum foil isn't necessary.
It only costs a few pennies (or other very small currency) to make, so you can easily experiment with different shapes.
Thats neat. Is the big white panel the piece of the jug?elf wrote:I made mine with foam core lined with aluminum foil and a piece of plastic from a milk jug. Masking tape was used to hold it together and a rubber band to hold it on the flash. If you use white foam core the aluminum foil isn't necessary.
- Cyberspider
If I have to use a light I'm using one or two LED flashlights (like a maglite not for the camera!) like this:
flashlight left and right of the mushroom
... if I use a camera flash I take the 430EX indirectly over a silver reflector and shut the camera via IR shutter release...
best regards
Markus
SONY a6000, Sigma 150mm 2,8 Makro HSM, Extention Tubes, Raynox DCR-250
visit me on flickr
Markus
visit me on flickr
