Harold Gough wrote:On the matter of diffraction in lenses in general, I have always understood that the concern is about that arising from the edges of the diaphragm.
That understanding is not correct.
The edges of the diaphragm really have no significant effect.
What matters is that the aperture restricts the maximum angle between light rays, which in turn restricts their ability to interfere with each other to produce differences in intensity that the sensor can detect.
Graham Stabler and I had a long discussion about this some months ago. The discussion is hard to follow, and then takes off on another point, but take a look at the illustration at
http://www.photomacrography.net/forum/v ... 0&start=47 .
The point is that light rays striking the sensor at relatively steep angles with respect to each other can interact to form fine patterns of intensity, while light rays striking the sensor at narrower angles can only form coarser patterns.
DOF depends on the same angles, hence my comment that there is no free lunch -- the tradeoff between DOF and sharpness is the same no matter how you get the magnification. The nominal setting of the lens to get a particular DOF/sharpness will vary depending on whether you use extension or a teleconverter, but the combination of DOF and sharpness will not.
