Focus Blending using Adobe Photoshop CS4
- augusthouse
We should be able to 'refine' the hard edged masks and instruct the software to use better segments where required as long as it doesn't mess with color blending or trip itself up in trying to be too clever.
Also, we need to supply the software with a 'deep' enough stack composed of 'fine' enough slices relative to the objective/lens/camera in use.
It should provide a good headstart to a manual composite. There is hope for it yet.
- augusthouse
The Adobe CS4 demo (30 day trial) is now available. 815MB
Just as a side note. Here is a quote from Graham Stabler. It was in another thread here and has relevance to my earlier question in regard to determining the focus state of a pixel.
You cannot tell if a single pixel in an image is in focus by looking only at that pixel, all you get is an intensity level, three for colour images. You must look at the variation of the image through that pixel. In focus parts of an image are generally much sharper, the spatial frequency is higher. That is one way to detect in focus information.
- augusthouse
CS4 deserves respect!
For this shot I used the Olympus RMS Macro 38mm, wide open at f3.5.
One SB28 speedlight (@1/8th output), bare, 35cm from subject top-left; subject diffused with artist's acetate cylinder. Nikon D100.
This particular image was shot in 15 micron increments - there are some flat spots or banding, so I am intending to re-shoot at 10 microns - unless 5 is suggested? The image is sharper than the 200kb forum image indicates. I'll be more particular the next time 'round.
CS4 has some system related issues/requirements, most of which can be tickled into submission; but a 64bit OS with a truck load of RAM would be nice.
This particular stack consists of 22 image slices; basically just loaded into layers; aligned and blended. The stack could have been deeper to take into account some of the overlapping 'hairy' bits.
Papilio ulysses (it's for a project I'm involved in)
Full frame (D100 sensor), minus edges crop.
Pixel crop
Pixel crop
It, CS4, and you have my respect! I'm still using CS2 so it's ppsibly a time to upgrade.
Very nice images. I've been following all the techniques discussions and was almost convinced that I needed some sophisticated fiber optics setup (currently using 1 flash). However, these images with 1 flash and a piece of plastic says to me that I don't need the fiber optics. Doesn't mean that "if you can do it" "I can do it" but it gives me hope.
NU.
student of entomology
Oliver Wendell Holmes, Sr
- augusthouse
Here is a second version of the image in my previous post.
Spot the difference (I know it's not easy at this scale and resolution). One is the output from CS4 and the other from Helicon Focus - in that order.
32 images at 10 micron. I used a different diffuser this time and a small amount of fill flash from the right in addition to the SB28.
Playing with the iridescence on the wings and diffusers whilst attempting to keep the highlight blowout balanced - long way to go I know.
I'm running a 32Bit Vista System with 4GB of RAM, minus whatever the OS reserves. I've been receiving some ' cannot perform...out of RAM" error messages from CS4. I found a way around some of those hurdles. I expect those error messages would come much earlier in the process if I were working with larger DSLR files.
The butterfly scales are impressive. I think CS4 can do a good job on relatively flat objects like this. It also seems to do a better alignment than CombineZM. An interesting test would be to align the images in CS4, crop to remove transparent areas, export layers as files, then stack in CombineZM and Helicon Focus.
My latest experiment was with a $3 Hong Kong postage stamp. It's a four frame pano and CS4 didn't have any trouble with the focus stacking or the pano stitch. I also didn't shoot the focus stacks with a small enough increment. Live View just isn't good enough to judge focus unless it's zoomed in.
The eye is about 1mm, so this is was approximately 10x. At 250dpi this would print at 15"x40".
HF image shows more fine detail; scales along the lower edge of that large vein and the scales adjacent to it lack definition in the CS4 image, much clearer in HF.augusthouse wrote: Spot the difference (I know it's not easy at this scale and resolution). One is the output from CS4 and the other from Helicon Focus - in that order.
NU.
- augusthouse
- augusthouse
NU wrote:
CS4 interpreted the iridescence of the scales more acurately in this particular exercise.
Yep...What was interesting is that there was certain, fine detail in one particular area which both programs elected to ignore - identically. I'll go into more detail later.HF image shows more fine detail; scales along the lower edge of that large vein and the scales adjacent to it lack definition in the CS4 image, much clearer in HF.
- augusthouse
- augusthouse
Here are two images.
Both images were stacked in Helicon Focus.
The second image was pre-aligned in CS4, edges cropped, layers exported as individual files and stacked in HF. I cannot see much difference with the full resolution files; but then I wouldn't expect to because the alignment in HF is built into its processing, so it would have re-re-aligned the files according to its own criteria.
I ran the files through CZP and bypassed the aligment proceedure, but the result was rather scary. Need to apply more time before uploading that result.
I was playing around with diffusers and lighting at the same time, and I expect you are tired of looking at blue scales; but that is what I am working with at the moment.
Helicon Focus, Nikon CF M Plan MI 10/0.25 210/0
Helicon Focus - pre-aligned in CS4, Nikon CF M Plan MI 10/0.25 210/0
