Magnification is about 4x, 205mm extension with 50mm lens on 4/3rds sensor. 36 images stacked at .05mm increments. The individual seeds are about 2mm in diameter. f8 @4seconds
Stacking is automatic in CS4, no options to select or modify. It appears to do fairly well but I haven't tried it on anything hard yet.
Cobweb: a stack using CS4
- augusthouse
elf,
Interesting image.
Are you using a beta of Photoshop CS4? It's good to see the 'big guns' thinking about focus blending. Should make for some interesting research. The focus blend is automatic; but there are layer masks in there and these can be manually adjusted. Would still like to see some parameters; but very interesting none-the-less.
http://www.photoshopuser.com/?page=cs4/ ... depthfield
Interesting image.
- augusthouse
