| Author |
Message |
Gary W Brown
Joined: 02 Mar 2008 Posts: 114 Location: Omaha, NE USA
Posted: Mon Oct 06, 2008 6:01 pm Post subject: By the tilt of the cap... |
By the tilt of the cap you can tell this is one fungi... ...
 _________________ A pixel is worth a thousand words but it takes a thousand words to explain a pixel. |
| Back to top |
Joined: 27 Jul 2006 Posts: 6574 Location: Western North Carolina
Posted: Mon Oct 06, 2008 6:14 pm Post subject: |
You know I have been following the discussions on these things in the forums, they are about as complicated as the little wasps that I have become fascinated with here of late. Good shot though Gary , though the cap is a little blown at the top. If your are using Photoshop there is an adjustment to darken the highlights a bit, you will find it under "Enhancments/Contrast and Brightness." As for what kind of mushroom it is I haven't the foggiest!  _________________ Ken Ramos
Rutherford Co., Western North Carolina |
| Back to top |
Harold Gough
Joined: 09 Mar 2008 Posts: 5732 Location: Reading, Berkshire, England
Posted: Mon Oct 06, 2008 10:53 pm Post subject: |
It's probably an Agaricus.
I am seeing blue sections of grass stems, especially in the bottom and mid right of the image. Am I alone in this?
Harold _________________ Happiness is having the right adapter.
My manual flash setup for high magnification:
http://www.photomacrography.net/forum/viewtopic.php?p=117843#117843 |
| Back to top |
rjlittlefield Site Admin
Joined: 01 Aug 2006 Posts: 12576 Location: Richland, Washington State, USA
Posted: Mon Oct 06, 2008 10:59 pm Post subject: |
| Harold Gough wrote: | | I am seeing blue sections of grass stems, especially in the bottom and mid right of the image. Am I alone in this? |
Nope, me too. Odd effect. Wonder what's going on?
--Rik |
| Back to top |
Harold Gough
| Back to top |
DaveW
Joined: 04 Aug 2006 Posts: 1702 Location: Nottingham, UK
Posted: Tue Oct 07, 2008 12:58 am Post subject: |
Could it be chromatic aberration in the lens from light reflected off the grass stems concerned? Particularly if these individual stems were wet and acting like a mirror.
http://www.vanwalree.com/optics/chromatic.html
Digital sensors show up any chromatic aberration in photographic lenses more than film used to.
DaveW |
| Back to top |
Gary W Brown
Posted: Tue Oct 07, 2008 5:18 pm Post subject: |
Thanks to everyone for your comments and suggestions. Ken, my PS elements 2 did not seem to have the adjustments that you recommended so I downnloaded a trial version of elements 6 and tried your suggestions (result of one set of changes is posted below). Harold, Rik, and Dave, I went back to the scene and looked for blue stems and there were none. It was an afternoon around 5:00 pm when I took the original digital photo (hence the overexposure on the mushroom cap) and there was no surface moisture on the grass. My camera is a Sony a100 and my lens is a Tamron 90mm 1:2.8 macro. Any additional insights are welcomed. Thanks again. Gary
| Back to top |
Posted: Tue Oct 07, 2008 5:34 pm Post subject: |
Was there perhaps something intense blue near the scene, that could have been reflected by a few blades of grass that happened to be sitting at the correct angle? I notice that the extreme right of the lower portion of the mushroom stalk has a similar blue cast to it. There are also a couple of patches of similar blue in the far right background.
Regarding the rework, I don't think these modifications are an improvement. A bunch of intense noise has gotten added, not only to the background but also on the mushroom gills on the right side. And the top surface of the mushroom has gone from being very light with a bluish tinge, to more of a slate gray that I'll bet looks a lot different from the real mushroom. I'm quite happy with the first picture. A bit less exposure at the time would have been good, to avoid blowing out any of the cap. But once the overexposure has happened, there's really no good way to fix it in post-processing.
--Rik |
| Back to top |
Harold Gough
| Back to top |
