www.photomacrography.net :: View topic - Caddisfly larvae in Idaho
PostPosted: Fri Sep 12, 2008 11:10 pm    Post subject: Caddisfly larvae in Idaho Reply with quote
Skipping to the end of the story, here are some caddisfly larvae, live and feeding in running water.
Location is the Lochsa River at White Sands campground, near Lolo Pass on the Idaho-Montana border, approximately 4100 ft elevation, August 17.
Case length of larvae about 10 mm.
What I first saw were these funny square cases, sticking straight out from rocks just above water level next to the river. (Look in the extreme bottom right of the picture.)
On closer inspection, they looked like this.
I'm pretty sure that those are caddisfly larvae in image 1, and the left-over cases of same in images 2 and 3. But these shots are basically "drive-by macro" -- I camped only one night at this spot and had no opportunity to follow these things through their development cycle. I'm only taking it on faith and general similarity that all three images show the same beasts, and I have no idea how the cases might transition from the flat posture shown in image #1 to the perpendicular posture shown in #2 and #3.
Any subject-matter experts out there, please feel free to chime in with additional or contradictory information about these things. Very Happy
Technical: Canon A710 IS camera, no accessories. Image #1 was shot with on-camera strobe, no diffuser, cropped to about 40% of field width.
Edit: to correct technical info.
PostPosted: Sat Sep 13, 2008 2:10 am    Post subject: Reply with quote
Great shots Rik! In the first one it looks as tho the camera is under water! Nice job!
Canon 10D | EOS 300 (Rebel-film) | Panasonic FZ-7 EB | Vivitar/Cosina 100mm f3.5 macro lens | EF 75-300 f4.5-5.6 USM III | EF 50 f1.8 II | Vivitar Series 1 19-35 f3.5-4.5 | Slik 88 Tripod. | My macro shots:
http://stumm47.deviantart.com/gallery/#Macro-and-Close-up
View user's profile Send private message Visit poster's website MSN Messenger
P_T
PostPosted: Sat Sep 13, 2008 4:06 am    Post subject: Reply with quote
The first photo made them look like they came straight out of a monster film. What is that yellow stuff in the first image and what are they doing sticking their legs out like that?
NikonUser
PostPosted: Sat Sep 13, 2008 4:50 am    Post subject: Reply with quote
Close-up photos of the bits and pieces used by the different spp. of caddisfly larvae would make an interesting montage.
Really have no idea what these are but they do fit some descriptions of Brachycentrus spp.:
cases square in cross-section; made of sand or pieces of plant debris; found in running water including cold mountain streams. 34 spp. widespread.
PostPosted: Sat Sep 13, 2008 4:54 am    Post subject: Reply with quote
Caddis larva are always fascinating to come across. I am amazed at how they construct these tiny to small cases with such delicacy and accuracy.
I had a few of these in a white plastic tray once, while out seining a mountain stream for various benthos, to see just how many different ones I could find. When placed in the tray with other caddis and benthos, they proved to be quite aggressive. Not only aggressive to other benthos but towards each other as well. One caddis I noticed, was taking on a very large Stone fly nymph that I had placed in the tray! Wonderful and interesting photos there Rik, things like this always seem to capture my attention. Very Happy
Rutherford Co., Western North Carolina
"Social isolate?"
P_T
PostPosted: Sat Sep 13, 2008 5:24 am    Post subject: Reply with quote
It's also fascinating how they make square boxes. I thought it would've been hexagonal.
PostPosted: Sat Sep 13, 2008 2:00 pm    Post subject: Reply with quote
Thanks for the compliments, questions, and added info!
It does, doesn't it? The actual setup was that the camera was positioned a couple of inches above the water, looking a little bit downward into a smooth flow. The surface of the water had moving waves, but with flash and some good luck, I got a few shots that were looking through clear "windows" between the waves.
The yellow stuff is a slippery film that grows on underwater surfaces. I presume it's a combination of bacteria and algae, probably teeming with protozoa too.
The legs are probably being held out to snag passing prey or other organic particles for food. Various caddisflies have different diets and methods for collecting their food. Some of them even spin underwater nets. Just from appearances, I'd guess that the strategy of these critters is to sit still and let the river bring food to them in big chunks.
augusthouse
PostPosted: Sat Sep 13, 2008 4:25 pm    Post subject: Reply with quote
So, they are initially mobile and then form small sky-scraper cities. They certainly appear to be well attached to the rock.
Quote:
A basic distinction of pupation for almost all case-making species is that larvae undergo a metamorphosis within their case, thereby retaining the energy and silk protein already invested in the portable case. Pupation behaviour is indicated when the larvae fastens the case with silk to a firm substrate such as rock or large piece of wood.
Page 59 link below.
Caddisflies - The Underwater Architects
PostPosted: Sat Sep 13, 2008 6:22 pm    Post subject: Reply with quote
That sounds right.
Now notice that in image #3, you can see that the center case appears to still be capped, while the rightmost case appears to have been capped at one time, but now the cap is popped loose and sitting crosswise in the wide end of the case.
I presume that these particular cases are now above water only because the water level has dropped. The reference that you found (great reference!) does mention death of pupae due to receding water levels. I'm only speculating, but it's possible that what we're seeing here are a couple of cases (left and right) where the occupants successfully completed development and got out before the water dropped, and one case (center) where that didn't happen.
PostPosted: Sun Sep 14, 2008 9:05 am    Post subject: Reply with quote
Excellent photos Rik. Could they actually relocate themselves above the waterline and change to a vertical position for final development?
PostPosted: Sun Sep 14, 2008 10:22 am    Post subject: Reply with quote
Don't know. The reference mentions only pupation underwater.
But that upright posture is a head-scratcher in any case.
The larvae I found were located in pretty rapid flow and I think it would be difficult or impossible for them to hold an upright position against it.
So either I'm wrong about that, or they found a quieter place to pupate, or they did it above water as you suggest, or the upright posture is something that happens as a side effect of drying out, or something else that I haven't thought of yet. That last one is always a good way to bet. Wink
PostPosted: Sun Sep 14, 2008 10:56 am    Post subject: Reply with quote
From what I have read, caddis pupate underwater and explode to the surface as adults, driving tout wild! Some caddis make it some don’t, either to adulthood or at the mercy of the trout. As for them standing up like this, they look to be quite large from those that I have seen here but standing up like this may facilitate the rapid escape to the surface. Probably a difference in species east to west. However, those that don’t make it to adulthood are more than likely the reason for mass egg laying, to ensure the survival of the species. From what little I have read on insects in general, not all hatch successfully. For the most part of what I have observed while out fishing, it seems Caddis and Mayflies attach themselves just inside the boundary layer that occurs between the substrate (rock) and the flow of the water across it. It is much calmer there and they are less likely to be swept away by the faster moving current.
Tight lines, ya' all!Very Happy
"Social isolate?"
Harold Gough
PostPosted: Sun Sep 14, 2008 10:45 pm    Post subject: Reply with quote
Very interesting. I was unaware of the square design. In the UK I believe we get stick versions or stone versions, nothing so geometric as square.
Harold
Committed to the use of fine grain colour reversal film and manual focus lenses.
PaulFurman
PostPosted: Tue Mar 23, 2010 8:12 pm    Post subject: Reply with quote
When I was a kid in Colorado, at summer camp near Steamboat Springs, these guys used garnets in their protective tubes. Garnet is like a poor man's ruby but I was impressed!
