Cranefly stack
acerola
Cranefly stack
Post by acerola »
I have a new camera. I finally bought a Canon 40D. The 20D was a very good camera but the 40D was not too expensive and Charlie article about the silent shoot mode was the last push to buy it.
I also tried a new lighting method. I used a Led torch with ping-pong ball diffusion.
Here is the result.
Canon 40D, Nikon 10x objective, 1s, 47 picture stacked with Tufuse
I like the live mode very much, I can compose the picture a little better.
Péter
lauriek
Post by lauriek »
Nice work! I like it a lot!
Did you do any unsharp-mask after resizing for web? as the eye does not look as sharp as it could be... These days I do an unsharp mask as the final piece of PP on the full sized image, then resize for web and do another (very mild) unsharp mask on the 800px sized image...
I also find the LV on my Olympus very useful for getting things setup nicely in front of the camera...
Does the LCD on the 40D tilt? On mine I can tilt the screen up so I can look straight down on it (only with the camera in horizontal mode unfortunately) then I can look down on the whole camera/bellows/subject setup and fiddle with the subject until it looks right on the screen. On my old camera without LV I would play with the subject, have a look through the viewfinder, play with the subject, check the viewfinder, adjust the subject, ad-infinitum..
acerola
Post by acerola »
Yes I did USM on my workplace TFT monitor. It seemed good enough for me then. It is not so sharp on my home CRT monitor.
I did not know any Canon DSLR with tilt screen. But it is just the first generation of DSLRs with live view. I did not miss it yet, the view angle is very good. And I can use the Video out for this type of application if I need it much.
Péter
lauriek
Post by lauriek »
acerola wrote:And I can use the Video out for this type of application if I need it much.
Yes that was my thought too for when I have the camera in portrait orientation, as the screen does not rotate on my camera, just tilt...
