The EOS 40D's CMOS sensor has an electronic 1st-curtain shutter function, enabling shooting with the mechanical shutter completely open. With Live View Function image displayed, the 40D can shift seamlessly to slit exposures with the electronic 1st-curtain shutter, enabling silent shooting which is not possible with a mechanical 1st-curtain shutter. This electronic 1st-curtain shutter uses a unique high-speed scanning and electronic reset system that accurately mimics the EOS 40D's high-speed mechanical shutter operation. It synchronizes with the mechanical 2nd-curtain shutter to obtain a slit exposure. (Note that with CMOS, it is difficult to have an electronic 2nd-curtain shutter. Therefore, only the 1st-curtain shutter is electronic.)
This is not mentioned on the 40D instruction book. But it might be of great significance to people who want to use a DSLR on a microscope or on a bellows for very high magnifications. In these cases not only is the mirror mechanism a problem, but the shutter mechanism alone is sometimes enough to cause significant vibration problems. I don't have a 40D, but the way I read this is that when in "Live View" mode, with camera set to "Silent Mode" the following occurs:With the CMOS sensor's electronic 1st-curtain shutter, shooting is possible while the image with Live View Function is displayed and the mechanical 1st curtain is open. The mechanical 1st curtain need not be closed in order to shoot.
The mirror is "up", and the mechanical shutter is open (since you are in "Live View"mode). When you "release" the "shutter" to take a picture, there is no need for the mechanical shutter to "close" before taking the picture. Canon has managed to incorporate an electronic 1st shutter curtain. The second shutter curtain (mechanical) is used to complete the exposure. It would seem like there would be only a very slight inertial "kick" when the second shutter curtain starts moving. The vast majority of any shutter vibration would likely occur when the 2nd curtain comes to an abrupt stop... but that's only when the exposure has already been completed. If this is so, it could certainly provide the lowest vibration DSLR operation I am aware of. Seems worth exploring a little more!
