Water Striders are "true bugs" that we've all seen scurrying around on the water's surface in streams and ponds. They have a piercing mouth which they use to suck out the contents of their prey. The parts of their legs that contact water are covered with tiny, grooved hairs. These grooves trap air and provide remarkable buoyancy.
(See: http://www.livescience.com/animals/0411 ... rider.html )
Nikon D200 with 105mm Micro-Nikkor, and additional extension tube. Electronic flash.
Water Strider
- Charles Krebs
- Charles Krebs
Laurie,
Yes they are alive, and as you mentioned, can be very active. I placed 3 of them in a small fish tank, with the water level just about 1 inch from the top. These seemed to be able to "jump" only about 3/4 inch. (Some species can fly at certain times in their life cycle, but these could not).
After awhile they settle down somewhat, and when they are in certain locations in the tank it's possible to get a nice low angle shot.
Ahh I wondered if you had put them in some sort of tank, I didn't realise only some of them can fly so couldn't see why they stayed put!
I spent a while trying to photograph some of these in the wild once, got one barely acceptable pic but not up to the standards of yours, and nearly got myself and camera gear very wet!!
- spidermanbryce2006
- Mike B in OKlahoma
Good work Charles, these are insects I've always wanted to photograph but never gotten a decent shot of!
Charles,
These are fascinating! The detail in the texture of the back is amazing. The best part to me is the indentation formed by the front "foot" in the water.What a perfect illustration of the effect of surface tension. You have even captured it lifting its leg out of the water in the third image.
I think I recall your photos of the feet of the Water Boatman a while ago.
Thanks for sharing your inspiring contributions.
Roy
Roy
