40-60 X Objective lens
iHasan
Post by iHasan »
Hi every one,
I am planning to buy an objective lens with 40-60 X range, and I found this in eBay
https://www.ebay.com/itm/Seiwa-Optical- ... 264488440
is it a good lens for the price ?
Scarodactyl
Re: 40-60 X Objective lens
Post by Scarodactyl »
Priced a little low, but it is probably not what you want. These are the super long working distance variety and have resolutions that are too low for photography at thst magnification.
Hard to know how good Seiwa's objectives are, not many test reports and iirc results are mixed.
Macro_Cosmos
Post by Macro_Cosmos »
Price is ok, but that's a 50x with an NA of 0.4, pretty low. You do get longer working distance, but a 50x with an NA of 0.7 is long enough for off-axis epi-illumination. If you have a Mitutoyo 20x normal M Plan which has an NA of 0.42, you will get essentially the same pictorial results by pushing it to 50x with a longer tube lens.
Seiwa objectives have mixed opinions. Based on what I've seen, it's not too good.
iHasan
Post by iHasan »
Any options for the same range ( and good price :mrgreen:)
iHasan
Post by iHasan »
Could this be a good lens for our photography work
https://www.ebay.com/itm/163710772822
iHasan wrote:
Fri Nov 13, 2020 3:41 am
It needs complementary aberration corrections done at a dedicated compensating eyepiece, so they only would be convenient with the adequate microscope, not for macro style work. More recent Olympus UIS and UIS2 series (UMPL... or LMPlanFL marked) don't need them.
This one: https://www.ebay.com/itm/Nikon-M-Plan-4 ... 0005.m1851
is a Nikon CF and can be used without eyepiece but being finite 210mm corrected it needs to be placed at 200mm of the sensor by extension (tubes or bellows)
40/0.5 seems clearly more convenient than 50/0.40 although the image still can't be very sharp on sensor
iHasan
Post by iHasan »
What is the difference between this lens and the famous nikon 40x lens?
https://www.ebay.com/itm/Nikon-M-Plan- ... 890.l49292
Higher resolution (0.65 NA) but much shorter working distance
viktor j nilsson
Post by viktor j nilsson »
If you check http://www.krebsmicro.com/mplan.pdf you'll see that the 40x 0.65 M plan has a working distance of 1mm, which is uncomfortably short.
iHasan
Post by iHasan »
One last objective :roll:
I try to learn new things as you give me more advises
I think this one has a good WD and A good NA, but the price is warily low...
https://www.ebay.com/itm/SPI-40-LWD-Mic ... 890.l49292
viktor j nilsson
iHasan wrote:
Fri Nov 20, 2020 4:42 am
Looks like a 160mm finite objective. In this era, the only ones that did not need compensating eyepieces are 1) Nikon CF and CFN objectives; and 2) some low-magnification objectives from Zeiss and Lomo (like the famous Lomo 3,7x).
So if you are looking for a 40x with longish work distance, you basically need to limit your search to a Nikon M plan/BD plan LWD or ELWD; or look for newer infinity-corrected objectives.
Macro_Cosmos
I have a similar looking 10x branded Edmund Optics, it too has a pastic back cap that says Japan on it. It might be alright, it's a 160mm finite objective. Never tried mine, bought it because it was $5.
