Afternoon All,
What is the hives opinion on white balance settings when using a Nikon attached to a microscope?
Many thanks
Paul
White Balance
Usually I do a custom white balance on an empty part of the slide either before the shots or later during raw conversion.
Be aware that
- if you use halogen lamp the colour temperature do vary a lot with the power setting
- if you use LED illumination a custom white balance is even more important as the camera presets are not well equilibrated for most LED models spectra.
(No Nikon involved, but it's the same with any camera)
Be aware that
Thank you so much.Pau wrote:Usually I do a custom white balance on an empty part of the slide either before the shots or later during raw conversion.
Be aware that
