I haven't decided yet.ray_parkhurst wrote:Are you going to mount both your subject stage and your camera / lens to the horizontal T-slot member? If so, then I'd personally recommend soft-mounting it. I like to use 3M wall-mounting double-stick tape for such purposes (the grey color, not the super-strong black). A few strips of it in strategic spots will hold it firm, and it will be relatively easy to move around. Best of all, no drilling! You can also tailor the resonance characteristics by putting on additional layers of the material. It has high dampening qualities so helps absorb higher frequency stuff coming from the table.
Edited to add: if the subject will mount to a different system which is mounted to the steel plate, then soft-mounting won't work well.
What I'd wanted to do was to use a combination of the 40mm x 40mm and 40mm x 120mm. Unfortunately, there's no linear bearing for the wide profile, making rough focus tough.
So I'm now looking at 40mm x 40mm for both vertical and horizontal. I don't think that would be stable with the vertical portion installed unless it was mechanically attached to the plate, or at least had transverse legs of some sort, a la Wemacro.
That also makes available space for horizontal shooting limited. I'd like to be able to shoot things bigger than pinned insects, so I'm probably going to have to rig up some kind of platform that will be attached to the horizontal profile.
