As I've mentioned in the Zeiss DIC thread, I picked up a bunch of Nikon reflected DIC Nomarski prisms with the hope of getting some sort of DIC-on-the-cheap working on my Wild M20 - Nikon CF frankenscope (described here: http://www.microbehunter.com/microscopy ... =24&t=6861) . I have no idea if it'll will work, but it'll fun to try. I'll post some updates when I get going.
Anyway, this has made me want to move forward with another idea I've had for a while - to build a flash setup for my microscope.
I've looked a lot at the different adaptations in Pau's FAQ: http://www.photomacrography.net/forum/v ... 563#161563
In my case, the M20 won't allow me to insert a beam splitter in the base where the lamp filament (in my case, LED) is located. So I'm thinking of making something more similar to Anne's solution with a contraption above the field lens:
http://www.photomacrography.net/forum/v ... 160#237160
I like the idea of having a collector lens built into the beam splitter assembly. I'm thinking that it would allow me to achieve Köhler with the flash.
But that's where I'm stuck. What lens should I use? Seems like in almost all cases it's a very simple convex lens? What focal length? Where would I buy one? Unfortunately I'm in Sweden, so surplusshack isn't an option. Ideas?
Collector lens for microscope flash setup
Marvelling at your fabrication skills so far Saul I must ask what ideas you have to make a focusable diffuser.Saul wrote: Also, later added diffuser (looks like I have to make it focusable, center of the field was little bit brighter)
The principles involved in solving this issue would be welcomed by others I am sure.
Thank you
BR
John
