Pyrite Crystals from Sugar Grove, WV
bralex
Post by bralex »
The shot is of 4 pyrite crystals, with 3 different crystal habits - 2 are elongated needles, 1 is a pyritohedron, and one is an elongated cube (oblong). The little vug that these crystals are in measures about 1 mm on a side, I don't have an accurate way to measure the size of the FOV or the crystals except that they are << than 1 mm! I only even noticed them because of the glint from the needles.
This specimen, for years, has been my white whale - I have simply been unable to get a good shot of it. This is leaps and bounds better than any of my previous efforts! Still a bit artifact-y in the background, I'll do a bit more cleanup there but I was very happy with it.
I'm using: Olympus OM-D EM-5 Mk II, Olympus 40-150mm PRO, Mitutoyo 10x objective
Cheers,
Scott
Did you use the automatic focus bracketing of that camera and lens? With such a shallow depth of subject, it might work.
bralex
Post by bralex »
Yes, I don't yet have an automated rail system - the internal focus bracketing works well for me thus far. I only wish I had a little bit more explicit control of the step size. There's a lot of trial and error involved for me.
I suggest using a step size of 6 or 7; with higher m the step size can be much larger than at lower m. This is counter-intuitive because it is the opposite of what you would do with a rail, or with a single lens.
bralex
Post by bralex »
I’ll have to give that a try. With the mitty lens I was worried that even the 1 step setting would be too much (it wasn’t).
Yes, that's what I thought too at first. It's just the opposite of what you would expect. You'll save huge amounts of time by choosing a higher number.
