Wave plate
Saul
Wave plate
Post by Saul »
Anybody tried this wave plate ?
Be aware of the small 13mm shorter dimension. Just after reading your post I clicked the buy button...I'm trying to cancel the order
Saul
Post by Saul »
Pau wrote:Be aware of the small 13mm shorter dimension. Just after reading your post I clicked the buy button...I'm trying to cancel the order
Yes, I saw that .
If cut in half, it could be placed somewhere close to the back of the objective. Another question - how cut it in half nicely this thin thing ?
Find a piece of sharp tungsten carbide. A corner on a new masonry drill is sharp enough. That'll scratch glass much more easily than a normal glass cutter. Then of course it snaps easily.
Saul
Post by Saul »
ChrisR wrote:Find a piece of sharp tungsten carbide. A corner on a new masonry drill is sharp enough. That'll scratch glass much more easily than a normal glass cutter. Then of course it snaps easily.
Yeah, it is standard procedure with glass..normal thickness glass ... :)
Did you try with this thin stuff ?
I don't know what "this stuff" is made of, but I've cut coverslips and slides easily. The point is you need a very sharp hard tool to scratch the glass with little pressure. Normal glass cutting tools need too much pressure to make the scratch.
If it's crystalline and you scratch it, & constrain the bend to the scratch, I wouldn't expect a problem.
Saul
Post by Saul »
ChrisR wrote:I don't know what "this stuff" is made of, but I've cut coverslips and slides easily. The point is you need a very sharp hard tool to scratch the glass with little pressure. Normal glass cutting tools need too much pressure to make the scratch.
Thanks Chris, you calmed me down ! So I bought it, let's see what will happen :)
I'm 4000 miles away, so I hope I'm safe :smt105
Smokedaddy
Post by Smokedaddy »
... probably wasting your time but why not use these?
https://www.edmundoptics.com/f/polymer- ... ilm/14827/
-JW:
Saul
Post by Saul »
Smokedaddy wrote:... probably wasting your time but why not use these?
-JW:
James, not at all, thank you very much for the link !
Any idea how this film affects image quality if placed above the objective ?
For below I'm using this polarizing assembly (tried different celolphanes), for now I'm pretty happy with it
Smokedaddy
-JW:
Yes it will.
I use the retarder film on top of a quality polarizer, which I then place on top of my Optiphot field lens. Guess I didn't understand your application.
-JW:
Saul
Post by Saul »
Smokedaddy wrote:Yes it will.
OK, it means it is affecting image quality. Maybe glass based will work better (as a upper retarder) ?
My setup is (except I do not have upper retarder - cannot use cellophane):
