Nikon objective question
Hi guys
I recently purchased a Nikon CF 160 Fluor 40/1.30 oil DIC objective.
It has a correction ring with a range that is 1.3 - 0.8
What is it correcting?
I have other objectives that correct for coverglass thickness, they have a range 11-23.
- iconoclastica
Maybe you are referring to the SC objectives, which are not CF, but was a series of student microscopes that had an extra lens system between the objectives and head? Discussed here: http://www.photomacrography.net/forum/v ... hp?p=64987Ichthyophthirius wrote:Hi,iconoclastica wrote:Speaking of nikon objectives: could anyone tell me what's the difference between cf-n, cf-e and cf-s?
I've never heard of cf-e or cf-s. Do you have a reference or illustration? All I know are Nikon CF, CFN, and CFI.
Otherwise I don't know what cf-s is either.
The CF series is well described in this folder, as I'm sure you are aware: http://www.krebsmicro.com/Nikon_CF.pdf
CF achromats and CF E achromats are very basic with pronounced field curvature. Some like the 10x is fine for stacking though as shown repeatedly on this forum.
CF E is the economy series. They are plan achromats and a VERY pronounced step up from the plain achromats and E achromats. I like them, very good value.
CF N is again a clear step up from CF E, but not as pronounced a step up as from plain achromats to E plan I'd say. They are also describred as plan achromats, but have higher resolution than CF E Plan. Nikon describes the CF N Plan as similar to Fluor objectives, which sounds about right.
And then there is CF N Plan Apochromats that I'm sure are superior but which I cannot afford.
I use 4x 10x and 100x from the CF E Plan series and 20x and 40x PH3 from the CF N series on my microscope and I'm pretty happy with all of them. I also have the CF achromat 10x which I am not using anymore but was OK for stacking when I was starting out.
- iconoclastica
Hm, it seems that in my eagerness to get confused I misread CFI-S for CF-S, for I cannot find the reference back indeed.
Anyway, your explanation of the -E and -N is most helpful and much clearer than the Nikon folder! Upto now, I avoided the E series, thinking that 'economic' meant cheapest and simplest...
--- felix filicis ---
If you are on facebook you can join the Amateur microscopy group, where Ken Schwartz some time ago posted a really good comparison of CF E Plan 40x 0.65 and CF N Plan 40x 0.70
It's here:
https://www.facebook.com/groups/Amateur ... 573470193/
Not sure if you can see it if you are not a member.
It's here:
- iconoclastica
