The versatile 28mm f/3.5 Nikkor
NikonUser
Post by NikonUser »
This is an old manual focus model, listed on ebay for <$50.00.
In my work on imaging bits of moths I have a need for magnification in the range of 5-10x on a FF Nikon DSLR
4x and 10x Nikon CFN objectives vignette badly on my setup but the image quality is so good that I can use just the center part of the sensor.
A simple procedure, which I have just started to use, gives adequate results for my purpose - posting 700px images on BugGuide.
Setup:
1] D810 Nikon, 1.4x teleconverter (this used to prevent dust entering the camera, it's been a permanent fixture on the camera body for 3 years and the sensor is still completely dust free!). I have no idea if this TC enhances or degrades the image, either way a permanent fixture.
2] Nikon bellows
3] reversed 28mm f/3.5 Nikkor.
4] vertical setup; flash.
At minimum bellows extension (=none) FOV is 6.8mm wide = 5.3x mag on sensor
At maximum bellows FOV = 2.8mm = 12.9x.
Some test images of a Cerambycid beetle eye
Top: min bellows, 5.3x; 50 frames
Bottom about 2/3rd bellows extension = 9.5x; 76 frames
Stacked with Zerene
Not as crisp compared to Mittys but good enough and simple to use.
NU.
student of entomology
Oliver Wendell Holmes, Sr
Tarloth
Post by Tarloth »
Fantastic! Which bellows you use? Nikon original?
That looks like a very satisfactory combination of
  • a simple setup,
    resolution matching the application to give good DOF,
    more working distance than a non-retrofocus lens would give you, and
    the lens has an iris you can play with.
    All without breaking the bank :).
"Other camera bodies are available"!
