www.photomacrography.net :: View topic - ITL 200 adapter
ITL 200 adapter
Saul
PostPosted: Wed Aug 22, 2018 1:17 pm    Post subject: ITL 200 adapter Reply with quote
Initial design
Because I wanted to use the ITL200 on the microscope also, went towards more universal solution (Ray, thank you very much for the illuminator and sorry for the cruel surgery Smile )
Camera version
Microscope version (could be used with the turret version with shorter objectives), kind a Optiphot infinity conversion
Objective dovetail adapter
ITL200 can be easily swapped between both versions (if needed)
RobertOToole
PostPosted: Wed Aug 22, 2018 2:53 pm    Post subject: Reply with quote
Hi Saul,
Whats the black objective again? Motec?
Don't forget, large end towards the objective, or large end downwards for best results.
Saul
PostPosted: Wed Aug 22, 2018 3:24 pm    Post subject: Reply with quote
Hi Robert !
It is LDM 50x
http://www.photomacrography.net/forum/viewtopic.php?t=32004&highlight=ldm+50x
http://www.photomacrography.net/forum/viewtopic.php?t=28661&highlight=ldm+50x
Narrow end downwards, like in the your drawing at the right ?
RobertOToole
PostPosted: Wed Aug 22, 2018 3:42 pm    Post subject: Reply with quote
Saul wrote:
It is LDM 50x
Thanks, right I thought you posted something on those before.
Those are some serious looking objectives Very Happy
Yes, correct! How did I get that wrong?
Saul
PostPosted: Wed Aug 22, 2018 3:50 pm    Post subject: Reply with quote
RobertOToole wrote:
...Yes, correct! How did I get that wrong?...
NP, who makes no mistakes, makes nothing Smile
You almost scared me, ufff ... I was already to start designing new inside adapter Smile
Adalbert
PostPosted: Sat Aug 25, 2018 9:51 am    Post subject: Reply with quote
Hello Saul,
Thank you for sharing!
I'm thinking about using of the step up ring 38mm-52mm but the most of them have the thread 38x0.75mm but not 0.50mm Sad
Do you have any idea?
Thank you in advance.
Best regards,
ADi
Saul
PostPosted: Sat Aug 25, 2018 10:08 am    Post subject: Reply with quote
Adalbert wrote:
...I'm thinking about using of the step up ring 38mm-52mm but the most of them have the thread 38x0.75mm but not 0.50mm Sad
Do you have any idea? ...
Hi ADi,
When I had Nikon MXA20696 and no 3D printing was available for me - very succesfully used M42 extension tube and few layers of the black electrical tape. Initially I made it for testing purposes, but it served for the rest of the time ... For one end (do not remember, it was for Morfanon or Nikon20696) you could use piece of the orange Walgreen's medicine pills vial, fits perfectly between tube lens and M42 extension ring.
RobertOToole
PostPosted: Sat Aug 25, 2018 11:00 am    Post subject: Reply with quote
Adalbert wrote:
Hello Saul,
Best regards,
ADi
Hi ADi,
FYi, There is a DIY trick if you have a spare Sigma LSA. You can unscrew the retainer ring and remove the glass and mount the ITL200 or MXA20696 in both normal and reverse. The retainer screws back in and holds the lens firmly in place. If I remember correctly it only grabs a few threads so be careful.
Here I have the Mitutoyo tube lens set-up the same way:
Also RAF camera does have a38mm x 0.5 to M42/M52 adapter.
Found it:
https://www.ebay.com/itm/M42x1-extender-15mm-with-additional-female-M52x0-75-accessories-thread-/142381047020?
Hope this helps.
Adalbert
PostPosted: Sat Aug 25, 2018 11:41 am    Post subject: Reply with quote
Hi Saul, hi Robert,
Thank you for the interesting ideas!
BR, ADi
