7 lenses at 2x.
Minolta DiMAGE Scan Elite 5400 Scanner Lens
Minolta DiMAGE Scan Elite 5400 II Scanner Lens
Nikon Scanner Nikkor ED 7 Element Scanner Lens
Canon 35MM f/2.8 Macrophoto Lens
Rodenstock 75mm F/4.5 APO Rodagon D 2X Lens
Optikos Teradyne 106mm f/2 Inspection Lens
Canon-MP-E 65mm f/2.8 1-5x Macro Photo Lens
This is the last part of the test, you can find the others here:
Part 1: http://www.photomacrography.net/forum/v ... hp?t=37028
Part 2: http://www.photomacrography.net/forum/v ... hp?t=37031
Part 3: http://www.photomacrography.net/forum/v ... hp?t=37032
Part 4: http://www.photomacrography.net/forum/v ... hp?t=37039
Setup
Camera: Sony A6300, model # ILCE-6300
Sensor size: 23.5 × 15.6 mm. APS-C. 28.21 mm diagonal. 3.92 micron sensor pitch
A series of images was shot with each lens in 10 micron steps, and the sharpest image was chosen for center, edge, and corner Photoshop at 100% actual pixel view. All images were shot as a single RAW files and processed in PS CC with all noise reduction and lens correction turned off, all settings were zeroed out (true zero) and the same settings were used for all of the images. All of the images shown here are single files.
Test target
This test is being broken up into sections for clarity. I am posting the lenses here in worst to best order.
Minolta DiMAGE Scan Elite 5400 Scanner Lens at 2x vs Minolta DiMAGE Scan Elite 5400 Scanner II lens at 2x.
The good news is that Minolta 5400 I and II versions are identical in performance, the bad news is that is was almost impossible to tell the files apart, so I am only going to post the center crops here.
To view any of the images in a larger size just click on any of these to open in a new window but the size depends on your browser to open at 1500px, right click on PC or two finger click on a Mac and choose open in a new Tab or new Window.
Center at 100%
Lateral Chromatic Aberrations at 200%
Top row, left to right: Rodenstock 75mm F/4.5 APO Rodagon D 2X Lens, Canon 35mm f/2.8 Macrophoto Lens, Canon-MP-E 65mm f/2.8 1-5x Macro Photo Lens
Bottom row, left to right: Nikon Scanner Nikkor ED 7 Element Scanner Lens, Minolta DiMAGE Scan Elite 5400 Scanner Lens, Optikos Teradyne 106mm f/2 Inspection Lens.
More details and the complete test can be found on my site: https://www.closeuphotography.com/2x-lens-test
Questions comments welcome.
2X Test Minolta Scan 5400 vs 5400 II Plus CA test results
