2X Test; Minolta Scan 5400 vs Scanner Nikkor ED 7 Element
RobertOToole
Post by RobertOToole »
7 lenses at 2x.
Minolta DiMAGE Scan Elite 5400 Scanner Lens
Minolta DiMAGE Scan Elite 5400 II Scanner Lens
Nikon Scanner Nikkor ED 7 Element Scanner Lens
Canon 35MM f/2.8 Macrophoto Lens
Rodenstock 75mm F/4.5 APO Rodagon D 2X Lens
Optikos Teradyne 106mm f/2 Inspection Lens
Canon-MP-E 65mm f/2.8 1-5x Macro Photo Lens
This is the third installment of the test, Part 1: http://www.photomacrography.net/forum/v ... hp?t=37028
Part 2: http://www.photomacrography.net/forum/v ... hp?t=37031
Setup
Camera: Sony A6300, model # ILCE-6300
Sensor size: 23.5 × 15.6 mm. APS-C. 28.21 mm diagonal. 3.92 micron sensor pitch
A series of images was shot with each lens in 10 micron steps, and the sharpest image was chosen for center, edge, and corner Photoshop at 100% actual pixel view. All images were shot as a single RAW files and processed in PS CC with all noise reduction and lens correction turned off, all settings were zeroed out (true zero) and the same settings were used for all of the images. All of the images shown here are single files.
Test target
This test is being broken up into sections for clarity. I am posting the lenses here in worst to best order.
Nikon Scanner Nikkor ED 7 Element Scanner Lens vs Minolta DiMAGE Scan Elite 5400 Scanner Lens at 2x
The Scanner Nikkor lens was tried in both directions to find the sharpest mounting orientation.
To view any of the images in a larger size just click on any of these to open in a new window but the size depends on your browser to open at 1500px, right click on PC or two finger click on a Mac and choose open in a new Tab or new Window.
Center
Edge
Corner
The Scanner Nikkor center is very sharp but the drop off in quality is rapid at 2x. The other direction was worse BTW.
Up next: Canon 35mm f/2.8 MacroPhoto lens vs Minolta DiMAGE Scan Elite 5400 Scanner Lens
More details and the complete test can be found on my site: https://www.closeuphotography.com/2x-lens-test
Questions comments welcome.
Clintonwake
Post by Clintonwake »
Excellent and thanks Robert.
I read your article/s on your site. I spoke to you sometime ago about the telecentric Nikon lenses ( Denis Hogan from Australia)
I have spent several days looking for this Minolta DiMAGE Scan Elite 5400 Scanner and sent emails to several shops locally but no luck.
Any suggestion where to find this scanner.
cheers
Denis
RobertOToole
Hi Denis,
PM or email me I can try to come up with something.
