Some fungus inside a pol filter before I attempt to clean it away.
Nikon 5x KNE IR 5x 0.13 on a Leitz Elpro 2 as a tube lens, Oly EM5 MK2
100%
fungus on polarizing filter
- enricosavazzi
Re: fungus on polarizing filter
Interesting picture, but it does not look like fungus to me. My best bet is that the Canada balsam used to glue the plastic polarizing material to a glass sheet has melted due to age and/or overheating, and what you see is a fractal-shaped bubble between the two materials. If so, there is no way to clean it from the outside.Munich wrote:Some fungus inside a pol filter before I attempt to clean it away.
I have seen this type of delamination in old enlarger lenses, probably with the same cause although located between cemented glass elements.
Fungus
1.0 Isn't nature beautiful?
2.0 Nature always finds a way.
