View previous topic :: View next topic |
Author |
Message |
RobertOToole
Joined: 17 Jan 2013 Posts: 1146 Location: United States
Posted: Tue Apr 03, 2018 10:22 pm Post subject: Scitex S-3 340 Smart Scanner Lens Removal Project |
Late last year I found a Scitex 340 scanner at a too-good-to-pass price so I decided to turn it into a project.
Since then I have not shot much with the lenses, they need to be mounted in reverse and they take a lot more extension, more than I expected.
Eventually I plan to create pages for each lens, 67,89, and 110.
Here is what I have found so far, hope you find this interesting.
The 110 lettering is reversed since it is mounted backwards in the scanner.
This scanner is huge, this is a full-size van and it takes up most of the cargo area. It weighs about 150+ pounds.
Scanner with the cover glass pulled. The servo motor only moves the Rogonar lens on the far left, I am guessing that this one is used for a preview scan maybe? The three S-3 lenses only move laterally and do not change position from the sensor. They are all a fixed distance.
These distances to the sensor are closer than I thought they would be. I have the exact measurements in my notes if anyone is interested.
This is the 67mm S-3 unmounted and mounted backwards inside a 52mm tube.
The two shorter lenses need to be mounted in reverse and they take a lot of extension to get the same distance to the subject as they are here from the sensor. I have shot some with the 67mm and it seems to be optimized for a certain magnification/distance. More or less and the performance drops.
This info can also be seen on my site:
https://www.closeuphotography.com/scitex-smart-340-s3-scanner-lenses/
If you have any info on the 340 scanner or S-3 lenses let me know. I would appreciate it.
Thanks.
Robert |
Back to top |
GaryB
Posted: Tue Apr 03, 2018 11:01 pm Post subject: |
nice project, I look forward to seeing how it goes. |
Back to top |
RobertOToole
Posted: Tue Apr 03, 2018 11:14 pm Post subject: |
GaryB wrote: | nice project, I look forward to seeing how it goes. |
Thanks.
Too many projects, not enough time!
My only free time coming up is in the second half of May! Back to back trips until then. |
Back to top |
GaryB
Posted: Tue Apr 03, 2018 11:15 pm Post subject: |
No rest for the wicked  |
Back to top |
zzffnn
Posted: Wed Apr 04, 2018 10:00 am Post subject: |
Great work, Robert! Thank you for sharing!
Lenses requiring long extensions may work well when mounted like microscope objectives on microscope stand (objective lens - DIY or factory lens turret - scope nose - head or extension tubes and/or camera).
I notice you use PPI (pixel per inch) for Scitex and you mostly used dots-per-inch DPI for Minolta scanner lenses. How do we compare those DPI vs PPI values (is DPI values printer specific)? Sorry, if this is a stupid question. _________________ Selling my Canon FD 200mm F/2.8 lens |
Back to top |
RobertOToole
Posted: Wed Apr 04, 2018 11:14 am Post subject: |
zzffnn wrote: | Great work, Robert! Thank you for sharing!
I notice you use PPI (pixel per inch) for Scitex and you mostly used dots-per-inch DPI for Minolta scanner lenses. How do we compare those DPI vs PPI values (is DPI values printer specific)? Sorry, if this is a stupid question. |
Glad you find it interesting.
I took awhile to share this because when I found this one, the next week I found another Scanner, a Scitex Eversmart supreme on Craigs list for $200 but when I called the seller, a lady was on the way over with cash already so I missed it by an hour or so. The Eversmart uses completely different technology with only a single lens that makes multiple passes. So I was looking for one of those to see what lens they used but I have given up by now.
I quoted DPI for the scanner lenses since that is what the Minolta uses but DPI is a printer specific term. PPI is used by everyone else, post production, designers, etc.
Robert |
Back to top |
SURF
Posted: Thu Apr 05, 2018 5:36 am Post subject: |
Hi! I'm in. First post here.
Quote: | The Eversmart uses completely different technology with only a single lens that makes multiple passes. So I was looking for one of those to see what lens they used but I have given up by now. |
They used Rodenstock Scitex LFOV 108mm f5.6. It is a great lens.
Quote: | The servo motor only moves the Rogonar lens on the far left, I am guessing that this one is used for a preview scan maybe? |
The Rogonar-S 60mm is for the whole glass scans (A3+).
I like Scitex Smart scanners a lot. BTW the scanners with letter "L" have 3 more lenses inside.
You can find some info about the lenses here:
http://www.largeformatphotography.info/forum/showthread.php?87538-DSLR-Scanner-Lenses/page7
(My posts starting from 2017). |
Back to top |
ray_parkhurst
Joined: 20 Nov 2010 Posts: 1896 Location: Santa Clara, CA, USA
Posted: Thu Apr 05, 2018 6:13 am Post subject: |
Good info in that thread. The 108LFOV is indeed superb. |
Back to top |
RobertOToole
Posted: Thu Apr 05, 2018 12:24 pm Post subject: |
SURF wrote: | Hi! I'm in. First post here.
Good info, thanks Surf! |
Back to top |
soldevilla
Joined: 16 Dec 2010 Posts: 523 Location: Barcelona, more or less
Posted: Fri Apr 06, 2018 8:19 am Post subject: |
zzffnn wrote: | I notice you use PPI (pixel per inch) for Scitex and you mostly used dots-per-inch DPI for Minolta scanner lenses. How do we compare those DPI vs PPI values (is DPI values printer specific)? Sorry, if this is a stupid question. |
No, is not a stupid question. I made myself the same ask a lot of years ago when I worked as graphic dessigner. The PPI or DPI that the builder write in the box of the printers is nothing about the final quality. Is about the precision of the mechanics. 300DPI is saying that the printer is capable to put a dot of ink with a precision of 1/300 inch, but nothing about the diameter of dot!
I feel that for scanner can be the same... |
Back to top |
ChrisR Site Admin
Joined: 14 Mar 2009 Posts: 8166 Location: Near London, UK
Posted: Sat Apr 07, 2018 5:38 pm Post subject: |
The scanner is big and is heavy.
Goes into a Honda CR-V only if you roll the rear seats forwards and then only lengthwise. Weighs 100kg (220 lbs). If I'd known that I wouldn't have lifted the thing in by myself. I thought, surely it can't weigh more than my wife, and I can lift her. But it does and the corners are sharper.
The 320, 340 and 342 models have the same lenses (different scan rates), "(L)" is not significant for us.
It's built like a part of a Type 42 destroyer I was once familiar with, though it's a mixture of imperial and metric hex screws. The quickest way to access the lenses would be to lift the lid and smash the glass with a heavy hammer. I removed a hundred or so screws instead, mostly the wrong ones, but I need to remove weight anyway.
There's a substantial looking stepper driven carriage in there - those bars are an inch diameter (lenses removed):
It cost £30,000 in 1996. Maybe the same as 4GB of DDR? That's about $50 now. I was robbed! _________________ Chris R |
Back to top |
RobertOToole
Posted: Sat Apr 07, 2018 5:54 pm Post subject: |
ChrisR wrote: | The quickest way to access the lenses would be to lift the lid and smash the glass with a heavy hammer. I removed a hundred or so screws instead, mostly the wrong ones, but I need to remove weight anyway.
Took the same route pulling the lenses, the hard way, but a power screw-driver saved me a ton of time.
I like to think that we are at least saving the optics from the junk yard. I have heard stories that when the manufacturer stopped supporting them, shops sent them straight to the trash dumpster!
Robert |
Back to top |
dolmadis
Back to top |
ray_parkhurst
Back to top |
Posted: Tue Aug 14, 2018 10:49 am Post subject: |
I have two sets of Scitex-3 lenses (67mm, 89mm, 110mm) and a set of Scitex-2 lenses (same focal lengths) recently rescued from several Scitex scanners. I'll be selling two of these sets. They are actually on eBay right now on my brother's account at very high prices until I fully test them and figure out what they are really worth.
It makes sense to treat them as a set, since each successive focal length is designed to cover about half the FOV of the next-higher one. The 110mm lens is designed to capture a 35mm slide; the 89mm lens is to capture a medium format slide, and the 67mm lens is for 4 inch x 5 inch large format slides. All are designed for reduction, so they have to be reversed for macro work. They are all around f/5 so not very good reversed on small sensors at the reciprocal of their designed optimum m. These are best on FF cameras and they cover the frame well.
So far I have tested them reversed on FF at 1x, 1.4x, 2x, 3x, and 4x. I also compared them (when appropriate) to the Printing Nikkor 105A, the Myutron 0.7x reversed for 1.4x, the famous DiMage 5400, and the Lomo 3.7x at 4x. Test results refer to stacked images, using DMap and high contrast setting.
1x: At 100%, PN105A was sharper and chromatically cleaner than the 110mm, but the difference was not huge. EDIT: 110mm should have been reversed!
1.4x: 110mm slightly soft but chromatically clean (EDIT: Should have been reversed!), 89mm excellent, slightly edging out Myutron. (Dimage and Lomo not tested at this m; in retrospect I should have tested the DiMage, which might well have beat the 89mm).
2x: 110mm poor (EDIT; Should have been reversed!). 67mm, 89mm, Myutron, and Dimage were similar in the center, but 67mm (especially) and 89mm (to a small degree) had some reddish haloes around the brightest white moth scale edges on black backgrounds. 89mm and DiMage were sharp out to the corners, unlike Myutron. DiMage wins at this m. (Lomo not tested at this m.)
3x: 67mm and DiMage (the only lenses tested at this m) were fairly close but DiMage is slightly sharper, significantly so in the edges.
4x: 67mm had slight red haloes around extremely bright edges. Lomo and Dimage were cleaner. Lomo beat DiMage; chromatically cleaner and also sharper, even in corners. (Other lenses not tested at this m since it is far from their designed optimum).
In summary, the Scitex lenses are good on FF at the reciprocal of their designed m, but not good general-purpose lenses. Nearly apochromatic at designed m, except for faint red haloes around very bright white edges in some cases.
It was interesting to see how good the DiMage and Lomo are! _________________ Lou Jost
www.loujost.com |
Back to top |
