Last month I found an open-box APO-lanthar 65/2 at a distributor so I picked it up for a nice discount. :-)
So far I have only had time to put this page up with the CA test results, and plan to update the page sometime in May with sharpness tests.
https://www.closeuphotography.com/voigt ... lens-test/
Can you help by recommending a few lenses that would people be the most interesting in seeing this lens up against? 1,2,3 choices would be helpful.
I have a Sony A6300 but I could borrow a A7RII or A7RIII for the test. I have all the mount adapters already.
My local dealer in Torrance has offered to help with any mount needed.
The new Sigma 70mm Art lens would be the first choice but since this is not available yet, I have the old 70mm Sigma.
Canon 100mm IS L?
Sony FE 90mm OSS macro?
Zeiss 100mm f/2 Makro Planar?
Tamron 90mm?
I have a mint Vivitar 55mm f2.8 macro that I picked up for less than $50 that might be interesting to test against the APO-lanthar.
Let me know what you think.
Thanks in advance.
VOIGTLANDER APO-LANTHAR 65MM F/2 Advice Needed Please
The old 125mm Apo-Lanthar, though it's rather long.
Good luck.
Whatever you find, you will have The PhARPs to please, as soon as you go there. These Photographers Achieving Refined Perception will denounce your tests unless you are able to show superior microcontrast, colour dimensionalilty, popping colors, depth separation, gradational clarity *, and a host of other attributes, all invisible to lower mortals - or those with unromanticized judgment.
Too many of the Pharps claiming to see and value these characterisics are some of the least credible indiviuals on the planet. The notion of using the same subject in exactly the same light, seems to be heretical.
However, I remain open to being convinced.
*I may have mis-remembered the adjectives or properties or put them in the wrong order. It actually doesn't matter, though the more correct combinations will be the ones least possible to measure objectively.
Good luck.
The standard Nikon 60mm G version is said to have very high resolution, though it is not apochromatic. It would make an interesting comparison. For some purposes (like scientific black-and-white photography using monochromatic light sources), CA problems go away, so a non-apo lens could still compete with an apo one.
60mm G Nikkor would be easy. Thanks Lou.Lou Jost wrote:The standard Nikon 60mm G version is said to have very high resolution, though it is not apochromatic. It would make an interesting comparison. For some purposes (like scientific black-and-white photography using monochromatic light sources), CA problems go away, so a non-apo lens could still compete with an apo one.
Thats a good one. Thanks. I had one or two of these years ago.mawyatt wrote:Robert,
What about the old Nikon 55/2.8 micro-Nikkor AIS. Mark over at Coin Photography shows it's pretty good.
From experience the 55/2.8 was sharp in the center but there was some CAs, the vivitar 55 I have now is similar, sharp as heck but neon CAs and LoCAs.
- enricosavazzi
Thanks Enrico the 60/4 CO would be an interesting comparison, I have a feeling the APO-lanthar might be sharper but I would guess the CO would be better corrected.enricosavazzi wrote:The CoastalOpt (now Jenoptik) 60 mm Apo would be a natural choice for comparisons, within its native magnification range (up to 1:1.5).
It would make sense to test a Sony Alpha 7RII (or III, although I don't expect much, if any, difference) also with its matched Sony 90 mm macro.
The CO 60/4 is available for rent.
All the best,
