Thanks ADi.
BR
John
4 Harley
Hello everybody,
Because of the CA the distance between the objective and the tube –lens has been reduced to about 50mm.
20:1 (NIKON LU Plan 20x / 0.40 ELWD )
https://farm1.staticflickr.com/889/4054 ... ec8f_o.jpg
50:1 (OLYMPUS MSPlan 50x / 0.55 ULWD)
https://farm1.staticflickr.com/869/2740 ... d8ee_o.jpg
80:1 (OLYMPUS NeoSPlan 80x / 0.75 ULWD)
https://farm1.staticflickr.com/791/2740 ... a98f_o.jpg
BR, ADi
BR, ADi
Hello everyone,
Enclosed you will find the current version of the tube and the bill of materials.
BOM:
1.) Adapter EOS-M => M42 ($4)
https://www.ebay.com/itm/M42-Screw-Moun ... Swb3laAvrv
2.) 4 sets of macro-rings M42 ($4 a set)
https://www.ebay.com/itm/Macro-Extensio ... 3a7a912982
3.) 2 sets of the clamps Harley-Davidson 49mm ($11 a set)
https://www.ebay.com/itm/49mm-Turn-Sign ... 2749.l2649
4.) Helicoid M42 ($24)
https://www.ebay.com/itm/M42-to-M42-Adj ... 2749.l2649
5.) Sigma LSA ($25)
Ebay Classified DE
6.) Iris M42 ($40)
https://www.ebay.com/itm/IRIS-DIAPHRAGM ... 2749.l2649
7.) Step-up/down rings M42 = > 52mm ($5)
https://www.ebay.com/itm/RISE-UK-42-52m ... 43f2ad15ad
https://www.ebay.com/itm/52mm-42mm-52-4 ... 35d008ff93
8.) Step-down ring 52mm => 52mm/30mm ($1)
https://www.ebay.com/itm/RISE-UK-52-30M ... 3abf8fe239
9.) Step-down ring 30mm/25mm ($1)
https://www.ebay.com/itm/RISE-UK-30-25M ... 3d14a3290a
10.) 4 Arca quick release clamp ($6)
https://www.ebay.com/itm/Black-For-Rele ... 2749.l2649
11.) Arca quick release plate double side 300mm ($19)
"https://www.ebay.com/itm/MENGS-BPL-300- ... 2749.l2649"
DE, Art 372195291005
12.) 4 screws UNC ¼ inch, ¾ inch long ($2)
https://www.ebay.com/itm/Linsenkopfschr ... 2749.l2649
13.) Flocked light trap ($5-15)
http://www.fpi-protostar.com/flock.htm
BR, ADi
BOM:
5.) Sigma LSA ($25)
Ebay Classified DE
6.) Iris M42 ($40)
BR, ADi
So you press the shutter release button manually, then move the rail, then press the button again, in order to do a stack? Tethering programs will shoot in RAW, so that's not a limitation that would keep you from tethering. Do you use the little screen to do your focusing?Adalbert wrote:Hello Ray,
I have never tried to do it, because I take the photographs only in the RAW-format and during the conversion from RAW into the TIFF I usually change some parameters and remove the CA manually.
BR, ADi
Hi Ray,
http://www.photomacrography.net/forum/v ... c&start=45
As I already have written, I change many parameters during the conversion into the TIFF.
These parameters depend on the lens, illumination and magnification.
So, I chose an appropriate picture, modify it and synchronize with the remaining pictures from the stack by LR and finally export to the Zerene.
I really don’t have any idea how to do it automatically with the tethering
BTW, yes, the display of the EOS M3 is good enough for the determination of the range of the stack.
BR, ADi
No, but everything is controlled by my macro-slat (Arduino based). This slat works standalone.So you press the shutter release button manually, then move the rail, then press the button again, in order to do a stack?
BR, ADi
